F/S: Falconer ported iron heads
  • Will'sFiero
    Too many valves
    • 276
    EDIT: DO NOT CALL FALCONER ABOUT THESE HEADS. Eric sold them to me to be rid of them. He does not have the time to field questions about them. I will post flow numbers as soon as I have them (shop says 1-2 days). Once that information is up, I will start accepting money and making shipments. I would not want to buy ported heads without flow numbers, so I'm not expecting anyone else to do that.
    [/edit]
    I will shortly have a lot of 19 iron heads of the type used in the 60 degree 6 racing effort in the late '80's. These are the heads used by Falconer on their 280 HP 2.8's and 300 HP 3.0's. That's 100 HP/Litre from naturally aspirated 60 degree V6's! The port work was done by BPE (www.bpeheads.com). Falconer ran 1.720 intake valves and 1.430 exhaust valves. I am currently trying to track down flow numbers, but these were done a long time ago and not everyone keeps extensive records for 20 years. I am told they were run in competition with approximately 0.560 lift. They are physically capable of 0.600, but there's no gain beyond 0.560.
    These heads are USED race heads that are in serviceable condition. These are NOT fully assembled, ready to run parts. Most are bare castings. I am told that several of them need seat clean-up and some of them may need more work, like guides.
    This is what the lot will contain:
    8 pair ported, uncracked heads
    1 pair ported, cracked, but repairable heads
    1 head, brand new, unported.
    The lot will also contain approximately 4 sets of used Titanium valves.
    I am claiming 2 pairs of heads and 2 sets of valves for myself. The rest I am putting up for sale.
    I would like to see $400 per pair of heads and $200 per set of valves.
    This is also posted to:
    RFT - http://realfierotech.com/phpBB/viewtopic.php?p=39120
    PFF - http://www.fiero.nl/forum/Forum4/HTML/031065.html
    Suggestions for other places to advertise would be welcome.
    Current:
    \'87 Fiero GT: 12.86@106 - too dam many valves; ran 12.94 @ 112 on new engine, then broke a CV joint
    \'88 Fiero Formula: slow and attention getting; LZ8 followed by LLT power forthcoming
    \'88 BMW 325iX: The penultimate driving machine awaiting a heart transplant
    Gone, mostly forgotten:
    \'90 Pontiac 6000 SE AWD: slow but invisible
  • Nightingale
    • Apr 2005
    • 259
    Any pictures of the heads and valves? Just curious on valve size, and port size/shape.
    98 camaro swapping in lz9 th400 setup
    LZ9 specs: (Subject to Change work in progress)
    4.0L(after bore 3.917 and stroke 3.3485),carrillo sbc rods(narrowed),wiseco custom forged pistons 8.5:1 CR, TCE Double Roller timing chain, gen 3 cam, P&P heads, headers 1 3/4 primaries into 3-1 collector, and going to run ms2.
      • 13531
      ebay:P
      How much for the brand new head? Id like one to do some testing on with my flowbench but I dont wanna spend a whole lot. Id like to get some stock readings though for this site since all I have are aluminum heads right now. Ill need stock valves though with the head but I can order those if need be.
      • Will'sFiero
        Too many valves
        • 276
        Hmm... I haven't been getting reply notifications for this thread.
        I'll have pics as soon as I get the heads.
        Intake valves are 1.720 and exhaust 1.430.
        We can work something out on the untouched head. PM me.
        Current:
        • geoffinbc
          Iron Head Enthusiast
          • 5831
          I'll proabably buy 1 set of ported heads once I see flow numbers. I wonder why he ran a larger exhaust. Usually a larger intake is installed.
          • sharkey
            • Jun 2004
            • 2061
            stock exaust is actualy listed at 1.42", my valves, both stock and si measure out to 1.425. whatever he used likley just made them 1.43", or they rounded it up.
            • Naft
              • Jan 2006
              • 19
              im possibly interested in a set, probably definitly if you get some flow numbers. do you know if they have been milled?
              • Naft
                • Jan 2006
                • 19
                you could also try advertising at www.thirdgen.org in the v6 and parts forums, and at fullthrottlev6.com in the 60V6 section.
                • StudlyCamaro
                  • Nov 2003
                  • 692
                  any update on these?
                  3.4L camaro some goodies
                  • Will'sFiero
                    Too many valves
                    • 276
                    Heads were supposed to be delivered today. They weren't. I'll give someone an earful about that tomorrow.
                    I should be able to get flow numbers by the end of next week.
                    What do I measure to see if a head has been shaved? What should the measurement be for a virgin head?
                    Current:
                    • Will'sFiero
                      Too many valves
                      • 276
                      Someone fouled things upstream of the local depot. I don't even have someone to call and yell at.
                      New arrival time scheduled for Monday.
                      Current:
                      • Will'sFiero
                        Too many valves
                        • 276
                        I received a pleasant surprise this afternoon... a pallet full of cylinder heads arrived.
                        It carried:
                        23 iron heads (20 ported, 2 cracked, 1 stock)
                        3 aluminum heads (2 with rectangular ports, one with trapezoidal ports)
                        24 pushrod guide plates
                        47 large rocker studs
                        12 small rocker studs
                        23 titanium intake valves
                        24 titanium exhaust valves
                        37 triple wound (or is it properly called dual w/ damper?) valvesprings
                        49 titanium retainers for small keepers
                        12 titanium retainers for large keepers
                        48 pr small keepers
                        12 pr large keepers
                        5 springs seats & associated parts
                        Pics to follow.
                        I will be taking a head and a pair of valves, springs and retainers to a shop next Monday. I'll have the head flowed and the spring measured.
                        In terms of sets, I have:
                        10 workable pairs of iron heads (putting 8 up for sale)
                        1 cracked pair of iron heads
                        1 stock head casting
                        almost 4 sets of 7/16" rocker studs (just missing 1)
                        1 set of 3/8" rocker studs
                        almost 4 sets of Titaium valves (missing 1 intake valve)
                        3 sets of springs + a spare
                        5 sets of titanium retainers & steel keepers (4 sets + spare for small keepers, 1 set for large keepers)
                        4 sets of pushrod guide plates
                        almost one head's worth of spring seats.
                        Current:
                        • Will'sFiero
                          Too many valves
                          • 276
                          I took two heads to www.justiceracingengines.com on Monday. They should be flowed by the end of the week.
                          Current:
                          • Will'sFiero
                            Too many valves
                            • 276
                            Deck and Chambers:
                            Exhaust Port Work:
                            Exhaust Port Face:
                            Intake Port Work:
                            Intake Port Face:
                            Valves, Retainers and Spring:
                            On the deck and chambers pic, you can see cutting marks from a very large diameter head. I'd say that this is the factory deck surface on this particular head.
                            Falconer is definitely on the west coast... Heads came with no rust-preventative measures taken but were rust free. They sat here for a week and already had surface rust. I used a whole can of WD-40 thoroughly spraying down ALL of them. This one is one of the worst and it's not very bad... I caught things in time.
                            Current:
                            • Will'sFiero
                              Too many valves
                              • 276
                              I *should* have flow numbers late this week or early next.
                              Current:
