Lq1 + 4t60e
  • hcomplyr
    • Jul 2006
    • 9
    Lq1 + 4t60e
    I have an entire LQ1 (minus injectors) and 4T60 with 108k miles out of a 1995 Monte Carlo Z34.
    I found a small piece of metal floating around in the cam carriers but it looks like that was the only issue, but, I did remove it doing so it needs the timing reset otherwise its fine. the 4t60E was working fine before i pulled it
    since the LQ1 isn't complete i'll part it out or sell the leftovers as a whole, cheap
    all accessories do work
    I need parts for my L36 swap sorry guys
    Parts list
    LQ1 block
    heads
    cam carriers + covers
    Injectors - sold
    fuel rail
    Complete wiring harness, not cut
    "DOHC" plastic trim
    alternator
    powesteering pump
    Coilpacks
    Upper plenum/Throttlebody
    AC compressor (its summer people!)
    OEM Serpentine belt tensioner
    NIB waterpump
    Lower Intake manifold
    Exhaust Manifolds + crossover
    Downpipe with cat
    Driver side + Passenger side Axles
    EGR valve
    Thermostat + housing
    95 4T60E transmission with torque converter
    I have to get rid of this thing!
    $200 + shipping for everything thats left, i need it gone
    • 13519
    where and how much?
    • hcomplyr
      • Jul 2006
      • 9
      whoops maybe I should have put my location
      Salem Massachusetts
      $250 for the engine right now as is, unless you wanted a specific part
      $200 for the transmission
      • FieroRush
        • May 2006
        • 4
        Meant to send this in a PM..
        • hcomplyr
          • Jul 2006
          • 9
          bump
          parts list updated
          • hcomplyr
            • Jul 2006
            • 9
            Bump
            take this PLEASE
            $200 for everything
            • GremlinZ34
              Other Member
              • Sep 2006
              • 23
              i would pay 200 for both... the question is, I live in PA, I used to live in Mass. how much to gwt it back to PA? DHL? LOL
              Is it sold already?
              1992 Lumina Z34: Artic White on Gray -Auto
              1987 Porsche 944: Slate Gray Metallic on Burgandy- Manual (Possibly for sale)
              • GremlinZ34
                Other Member
                • Sep 2006
                • 23
                oh, i forgot.... Email me at Kalamazoo3672@aol.com
                I will find a way to get it back, for 200, i'd def. buy it... just for parts its worth it!
                • bve32k
                  3.4 DOHC FTW
                  • Jun 2005
                  • 475
                  Does the power steering pump have the varible steering I believe it is called on it. Where it has the sesnor on top. Or is this just the GTP's that had them as a option?
                  • hcomplyr
                    • Jul 2006
                    • 9
                    well a day trip would probably be the cheapest route shipping is probably going to be double if not more, especially since it would be shipped from a residential address, they usually charge for crating
                    • GremlinZ34
                      Other Member
                      • Sep 2006
                      • 23
                      LQ1 + 4T60E = happy me
                      I agree. So, how does the engine sit currently? is every part listed b4 still there? do you know the mileage on the engine, or is the 108k on both? could I use it in my 92 Z34? I could come up soon and pick it up in a truck I'll borrow once I let the person I'm borrowing it from know. LOL.
                      • hcomplyr
                        • Jul 2006
                        • 9
                        the engine is sitting outside, covered, with the engine and transmission together, with all of the accessories and wiring harness still on. considering its a 95 and only after 96 did they really update the engine it should work with no problem. since its out of the car I would replace the timing belt and tensioner and reset the timing and it should be straight. the plenum is off and stored inside
                        • GremlinZ34
                          Other Member
                          • Sep 2006
                          • 23
                          I'm working out when I'm coming up there again. It'll probably the first or second week of October. I'll keep you updated, I'm totally stoked for this! My email is Kalamazoo3672@aol.com
