Performance Injectors 91-93 3.4 DOHC
  • HayesPerformance
    • 783
    Hey Everyone,
    I am Very happy to say that our Performance Shop sells BRAND NEW (Not re-manufactured from cores) performance injectors for the OBD I or 91' to 93' 3.4 DOHC. They feature very high craftsmanship and we have them made with LBS rating lazer etched on the side. They look as good as they work too!
    They feature:
    - High Ohms resistance @ 14 ohms
    - Available in 21 (stock), 23, 24, 26, and 30 lbs./hr flow rating
    - Perfectly balanced, 100% Bench flowed and MATCHED to +/- 1% of the flow rating
    - Precision ground from TOP QUALITY Billet steel
    - Super fine, wide angle spray pattern to aprox. 130 Micron diameter fuel droplets ( for MAX fuel atomization for better engine efficiency, throttle response, and increased power)
    - anti-plugging vapor cap eliminates a chance of any carbon build up.
    - Injectors have a Low-mass internal precision ground needle and a HIGH strength fuel pressure spring that have a MUCH faster response time and a VERY wide Dynamic range then stock or stock replacement units
    We sell the injectors WITH new Injector O-rings too!
    I have these injectors in my own GP 3.4 DOHC and I have to say I'm VERY impressed! These top other injectors I have installed just to see the difference, I honestly can't believe HOW SMOOTH the engine runs!!!
    I HIGHLY recommend them for someone replacing there factory ones,
    THEY WON'T BE DISAPPOINTED!!!
    They come with a 30 day warranty against ANY factory defects.
    We sell them for $68.85 US each plus shipping
    NOTE: I can have Injectors made for other engine applications too.
    BEST REGARDS TOO ALL HERE,
    David Hayes
    President of
    Hayes Performance Plus
    1991 Grand Prix STE
    3.4 DOHC
    1 of 792 Produced
    Extensive Mods Done
    1991 Lumina Z34
    3.4 DOHC
    Getrag 284 5spd
    1 of 30
  • gectek
    Banned
    • Aug 2006
    • 1472
    do you have any other injectors besides the ones for the 3.4 dohc like maybe a 99 or newer 3400 V6?
    • napatiger
      • 490
      works with 95 LQ1?
      95 MC Z34 Black
      • HayesPerformance
        • 783
        These injectors here don't work with the 94'-97' DOHC.
        Unless someone say they will, in that case go ahead but I won't back that up.
        Thanks.
        Regards,
        Dave
        1991 Grand Prix STE
        3.4 DOHC
        1 of 792 Produced
        Extensive Mods Done
        1991 Lumina Z34
        3.4 DOHC
        Getrag 284 5spd
        1 of 30
          • 13522
          94-95 should be the same thing. 96-97 use the same style injector as well so if you can do those ratings it shouldn't an issue at all. I dunno what stock ratings are for the 96+ motor though.
          • HayesPerformance
            • 783
            The 91' - 97' STOCK flow rating is 21lbs./hr
            Like I said, I will sell the injectors to someone with 94' - 97' IF THEY WANT THEM, BUT the only thing I do know is that if you check the part numbers on GM or other new injectors is that 91-93 are the same, 94-95 are the same and 96-97 are the same. Three different PN #'s for those years.
            I'm not responsible if someone WITH a 94' to 97' 3.4 DOHC buys them and THE DO NOT WORK.
            Best Regards,
            Dave
            1991 Grand Prix STE
            3.4 DOHC
            1 of 792 Produced
            Extensive Mods Done
            1991 Lumina Z34
            3.4 DOHC
            Getrag 284 5spd
            1 of 30
            • ryan.hess
              • 526
              Surely you have to reuse some parts to make them - like for the connector?
              How do you machine the orifices?
              Okay now, that's enough of that.
              • HayesPerformance
                • 783
                Hey,
                They are TOTALLY BRAND NEW, NOTHING IS USED!
                NOT A SINGLE PART!!!!!!!!!
                Best Regards,
                Dave
                1991 Grand Prix STE
                3.4 DOHC
                1 of 792 Produced
                Extensive Mods Done
                1991 Lumina Z34
                3.4 DOHC
                Getrag 284 5spd
                1 of 30
                • dnalbach
                  • Oct 2006
                  • 69
                  Do you have them for the '95 gen3 3100?
                  • Joseph Upson
                    I believe the difference relative to the injectors for the DOHC engine from what I faintly recall reading some time ago is that the DOHC injectors have a spray angle specific for the valve spacing, through 4 nozzle holes, two for each valve. So as long as they are the 12 ohm impedance type they should work but probably not as efficienctly as DOHC specific injectors.
                    • HayesPerformance
                      • 783
                      I have all the correct angles for the 3.1 , 3100's,
                      accually most of the V6's we all have in here.
                      I have heard from even more people that these injectors Will work in a 94' -97' 3.4 DOHC, but I personally can't say for sure.
                      1991 Grand Prix STE
                      3.4 DOHC
                      1 of 792 Produced
                      Extensive Mods Done
                      1991 Lumina Z34
                      3.4 DOHC
                      Getrag 284 5spd
                      1 of 30
                      • HayesPerformance
                        • 783
                        The flow rate on that 95' 3100 stock is 17lbs/hr
                        We can do injectors for that.
                        Let us know, Thanks
                        Regards,
                        Dave
                        1991 Grand Prix STE
                        3.4 DOHC
                        1 of 792 Produced
                        Extensive Mods Done
                        1991 Lumina Z34
                        3.4 DOHC
                        Getrag 284 5spd
                        1 of 30
