Data File Needed?
  • Jogasz28
    • Dec 2006
    • 132
    Data File Needed?
    I am in the middle of replacing my 1995 3.4 Litre Monte Carlo engine's timing belt and intake gaskets. Before I knew the gaskets were causing my idle problem, I wanted to see what the on-board computer was thinking was going on.
    I purchased the following OBD1.5(?) software license:
    I also purchased the OBD1 ALDL to serial cable required. When I loaded the software in my laptop, I was only able to see the streaming raw data and operating values like TP% and Intake Temp, etc.,. The dashboard and graphing features would not work as the data file I was using said it doesn't support that Macro.
    Is there a data file available that will let me use the dashboard and graphing features?
    jogasz28
    ______________
    '68 RS Camaro,
    Project '69 Camaro in the works
    '95 Monte Carlo Z34 loaded,
    '99 Monte Carlo LS
    • 13513
    If you are in a hurry, I can go look for my backup dvd (i lost my laptop HD info). I have the vehicle file you need, version 1.4. Im porting a manifold right now though so if you aren't going to mess with it tonight, I will look for it in a little while.
    • Jogasz28
      • Dec 2006
      • 132
      Thanks, no rush as the engine is torn apart right now and probly won't be back together for a couple weeks.
      I just saw the Tuning Forum and figured I would post this so I'd be ready for when I finished the engine work.
      Thanks again,
      jogasz28
      ______________
      '68 RS Camaro,
      '99 Monte Carlo LS
      • Jogasz28
        • Dec 2006
        • 132
        Ready For Data File
        Hey Sappy, Merry Christmas!
        Could I get that data file from you?
        I'm ready to check my ECM.
        TIA,
        jogasz28
        ______________
        '68 RS Camaro,
        '99 Monte Carlo LS
          • 13513
          I have to see if I can get it again. My hard drive crashed and I dont know if I have it anywhere else
          • Jogasz28
            • Dec 2006
            • 132
            Please let me know either way.
            Can I create my own data file?
            jogasz28
            ______________
            '68 RS Camaro,
            '99 Monte Carlo LS
              • 13513
              I have version 1.3. 1.4 is what was final for it I believe. You can create your own but you need to know the ALDL code. I have that part of the code but I don't know how to set it up personally. Ill upload what i have and we can go from there.
