Got a datalog, but important stuff isn't logged??
    Ok I got my definition file, and it shows up ALL the data for everything under the sun. I'm using TunerPro RT
    1) BUT when I go to log it, and view it, it's missing BLM's, O2, etc etc. All the important stuff I wanted to log.... What gives?
    2) When I click play back, it doesn't work. It does something but none of the values change, except the trouble codes, they all randomly go from OFF/ON
    3) Is it normal to have a few knock counts when starting the motor? That's when they show up.
    Below is a csv example... HELP!
    Missing info (aside from screwed up playback) :
    BLM
    INT
    Oxygen mV
    TCC Slippage
    IAC Steps
    Voltage at Fuel Pump
    Spark Advance shows up but as a weird #...
    All above values work fine in real time though..
    • 13534
    Can't help on the tunerpro datalogging but I do know that knock can be set off during start up.
    • merlot566jka
      • Nov 2006
      • 570
      on my lt1 i got over 1000 knock counts at start up! it was consitant too
      2012 Chevy Sonic Turbo 6spd
        Cool I figured it was due to the starter.
        • z34phoenix
          • Jun 2005
          • 469
          on my 96 DOHC pcm (obd2) that spark control is disabled unil like 5 sec after startup. also it is disabled for anything under 550 rpm and if the coolent is below 104*
