Prom & memcal 86 2.8 7032
  • TheFly
    86 Bird 2.8MPFI T5 3:42s
    • Mar 2009
    • 59
    Got my new ECM and all has been fine but twice now it has run funny with the flashing SES light. Which means its not readin the chips right or something????
    So Im on the hunt for a PROM & MEMCAL 86 2.8 7032 I guess.
    Just regular old stock stuff is fine with me.
    86 Pontiac Firebird
    [68 Firebird hoodscoops, custom notchback,
    custom rear mounted tach, inverted wing.]
    http://thirdgenchat.org/viewtopic.php?f=4&t=58
    I love my new notch-back. See link for better newer pics.
    the SES light flashing isn't necessarily the chip itself.
    • TheFly
      • Mar 2009
      • 59
      And?????
      86 Pontiac Firebird
        SES light could be damn near anything. do you know how to put the car into field service mode?
        and what do you mean by 7032? are those the numbers printed on the PROM?
          and the GM part number for your ECM is 1226870. interestingly, its the same one used as the 85 IROC-Z28 with the 305TPI.... i miss that car
            Live life 3.7mi at a time
            • 4555
            Did you try pulling the codes by jumping the connector under the steering wheel?
            And BTW, it's the 01227302 robert ... MAF based, no knock sensor.
            EDIT: Nevermind, it's you Gumby Did you do the same swap as 85blc?
              really? thats a rare miss for rockauto...
              • TheFly
                • Mar 2009
                • 59
                No this is the flashing near stobe light flashing like crazy, which in many searches all come up as its not reading one of the two chips. Several had put in a new ECM like me.
                This is not any normal code flashing.
                Havn't bother to hook up the laptop to aldl it. [got pissed n parked it.]
                All the post found say thr strobe like flashing is chips, unless its not???
                86 Pontiac Firebird
                  • 4555
                  Have you tried a different memcal, I know you said you tried a new ECM...
                  BTW, you get the vents safely I hope?
                  • TheFly
                    • Mar 2009
                    • 59
                    Don't have a diff memcal to try, looking for one though.
                    Not sure where to find them new if not to much.
                    86 Pontiac Firebird
                      a brand new 2732 chip? good luck...
                        • 4555
                        They are littered on ebay, just make sure you use a V6 memcal.
                        http://cgi.ebay.com/ebaymotors/COMPU...Q5fAccessories
                        • TheFly
                          • Mar 2009
                          • 59
                          I couldn't find any of them chips when I searched.
                          Anyone know how important them letters after the number mean?
                          like the link you posted is
                          ECM 1227302 HNJ
                          Are several others too like that.
                          My old computer says 1227302 HNT on it.
                          New computer doesn't say much but
                          7-7032
                          0499KM
                          86 Pontiac Firebird
                          • TheFly
                            • Mar 2009
                            • 59
                            I was just startin some layout test for them vent the day before it went nuts on me.
                            Deciced to just flush mount them insted of recess. No metal work, just copy the shape of the hole in the metal part, cut that out of the sides and install the vents as is.
                            Getting a easy way to lay it out and make it the same on both sides seem to be the only real trick. No good measuring points.
                            Anyone intrested in what Im talking about here, see this
                            Body - TA nose hood vents into the sides - OK get the flame machines ready for my next mod. TA nose hood vents into the sides of my Firebird. Where on the side, see pics http://buickthunder.com/TAvent1a.jpg http://buickthunder.com/TAvent1.jpg http://buickthunder.com/TAvent2.jpg http://buickthunder.com/TAvent3.jpg
                            86 Pontiac Firebird
                              thats the part number of the actual chip for your ECM...
                              you know what post some of the BCCs that you find and i might be able to find something that works for you.
