Prom & memcal 86 2.8 7032
  • TheFly
    86 Bird 2.8MPFI T5 3:42s
    • Mar 2009
    • 59
    Here is a pic of the tag on my old ECM
    [new one don't say jack]
    86 Pontiac Firebird
    [68 Firebird hoodscoops, custom notchback,
    custom rear mounted tach, inverted wing.]
    http://thirdgenchat.org/viewtopic.php?f=4&t=58
    I love my new notch-back. See link for better newer pics.
      you said you found stuff on ebay? post the BCCs (the three letters) and i'll tell you what they're meant for
      • TheFly
        • Mar 2009
        • 59
        Ohhh ok,
        HNJ
        HNR
        HUL
        AMBD
        AMBF
        86 Pontiac Firebird
          hnj:
          Model Year: 1986
          Release Date: 05/14/85
          EPROM Part Number: 16055624
          ECM Part Number: 01227302
          PROM ID: 5625
          SCAN ID: 2981
          Platform Codes: FB
          Engine RPO Codes: LB8
          Engine Displacement (L): 2.8
          Transmission RPO Codes: MD8
          Transmission Type: AUTO
          Gear Ratio RPO Codes:
          Emmission RPO Codes: +NA5
          Emissions Catagory: FED
          GVWR Ratings: C60
          aujc, an updated version of hnj:
          Model Year: 1988
          Release Date: 02/09/87
          EPROM Part Number: 16080006
          PROM ID: 0007
          SCAN ID: 9891
          Platform Codes: FB
          GVWR Ratings:
          Service Bulletins:
          S/B 87-108(CHEV)
          S/B 87-108(CHEV)
          S/B 87-108(CHEV)
          S/B 87-628-110(CAN)
          ambf, an updated version of ajuc:
          Model Year: 1986
          Release Date: 07/24/87
          EPROM Part Number: 16087038
          PROM ID: 7039
          SCAN ID: 7221
          Platform Codes: FB
          GVWR Ratings: C60
          hnr:
          Model Year: 1986
          EPROM Part Number: 16055638
          PROM ID: 5639
          SCAN ID: 3041
          Platform Codes: FB
          GVWR Ratings: C60
          ajuh, an updated version of hnr:
          Model Year: 1989
          EPROM Part Number: 16080020
          PROM ID: 0021
          SCAN ID: 9921
          Platform Codes: FB
          GVWR Ratings:
          Service Bulletins:
          S/B 87-6(GAS)-33(PONT)
          S/B 87-628-110(CAN)
          ambd, updated version of aujh:
          Model Year: 1986
          EPROM Part Number: 16087052
          PROM ID: 7053
          SCAN ID: 7211
          Platform Codes: FB
          GVWR Ratings: C60
          hul:
          Model Year: 1986
          Release Date: 06/30/86
          EPROM Part Number: 01228070
          PROM ID: 1158
          SCAN ID: 4841
          Platform Codes: AB
          Engine RPO Codes: LB6
          Transmission RPO Codes: ME9
          GVWR Ratings: C60
          Service Bulletins:
          S/B 86-160(CHEV)
          S/B 86-6(GAS)-59(PONT)
          S/B 86-628-107(CAN)
          your original chip, hnt:
          Model Year: 1986
          EPROM Part Number: 16055393
          PROM ID: 5394
          SCAN ID: 3061
          Platform Codes: FB
          Transmission RPO Codes: MB1
          Transmission Type: MAN
          GVWR Ratings: C60
          pick your poison...unfortunately those are all meant for auto trannies
            i'll help even more:
            hnl
            hns
            hnt
            hnu
            hnl
            hnt
            those are all for f-bodys with the lb8, the 5 speed and federal emissions on the 1227302 ECM. from various years, but they'll work
            • TheFly
              • Mar 2009
              • 59
              #21
              I need ones for a stick though, its hold the rpms a bit between shifts to help.
              86 Pontiac Firebird
                can you rephrase that, it makes no sense to me...
                • TheFly
                  • Mar 2009
                  • 59
                  #23
                  Wont I need a 5 speed stick chip, not an auto 5 speed.
                  Its said to be programed to rev down slower. It holds the rpms for a sec when you let off to aid in shifting. I member it coming up often when an auto guy would get a used stick prom at TGO.
                  86 Pontiac Firebird
                    those are all chips meant for manual 5 speed trannys. i dont think there was ever a 5 speed auto f-body.
                    and i imagine it losing less rpms would be due to the throttle follower opening up the IAC.
                    • TheFly
                      • Mar 2009
                      • 59
                      #25
                      well your list of what the different codes means, they all say
                      where mins is
                      Id probably still buy one to test things since its not that much.
                      86 Pontiac Firebird
                        did you see the second list i put up? those are all meant for your t5...
                        • TheFly
                          • Mar 2009
                          • 59
                          #27
                          Ok I was just worrying about the list of ones I posted as thats all that is for sale now. cheap though.
                          Im still real close to picking up a carb'ed motor for $100 and switching though.
                          86 Pontiac Firebird
                            if any of those come up, they should work for you.
                            • TheFly
                              • Mar 2009
                              • 59
                              #29
                              Well I did find an HNL
                              But man does the new ebay motors suck, you never find the same stuff twice with the same search words. Its like a total shot int he dark, like early search engines days.
                              They need google to fix things.
                              86 Pontiac Firebird
                                well that looks like it worked for ya. and did you try hitting the "original ebay motors" button, i know i do. price/link?
