94 GA OBDII swap
  • customgagt94
    • Dec 2009
    • 12
    94 GA OBDII swap
    hey i have a 94 grand am and im tryin to swap it to a obdII well i got the harness out and put in new one and i put in a PCM from a 97 GA, well it is showing me a passlock thing, which makes my car turn off once it starts (shuts fuel off) it is showing passlock code.. well my car itself doesn't have PASSLOCK, but the PCM does how do i go around this to get my car running..
    thanks for help everyone
    • 13534
    set the VATS to PWM and then turn off error checking for all VATS related codes.
    • customgagt94
      • Dec 2009
      • 12
      wat would that actaully do??
        • 13534
        Bypass VATS and let your car run.
        • customgagt94
          • Dec 2009
          • 12
          but i have passlock not vats.
          • customgagt94
            • Dec 2009
            • 12
            also that does not work i remembered i already did that couple days ago adn still a no go
              • 13534
              passlock is vehicle anti theft system, and what I described has worked just fine on the 96 achieva using a 97 grand am pcm. I guess you will have to install a BCM and match the VIN if you can't bypass it.
              • onefastV6
                • Sep 2005
                • 880
                Aren't you the guy that is having Milzy doing the swap? If so what all has he tried?
                If Milzy is doing it, he would be using HP Tuners, however HPT can not modify the BCM only the VCM (PCM).
                I would make sure that the VIN matches that of the car so it syncs with the BCM, set the VATS to PWM and try doing a security relearn by cycling the ignition. 15mins with key on then off for 15 and then key on for 15 mins and then try to start.
                There may also be a way to disable the PASSLOCK by soldering in a resistor that matches the resistance that the BCM is looking for. Is there a Chip in the key? ... I know some GM of the 90's vehicles has the chip in the key.
                2000 Grand Am GT
                2011 Chevy Impala
                • customgagt94
                  • Dec 2009
                  • 12
                  no chip, and no vats.. but it runs now lol switched pcms and changed a couple things on wire harness then tuned it for the bigger injectors andpurrs like a kitten.
