do any body know how to get the software to burn your own chips or do any of you guy's burn on the side?
custom chips
Tags: None
nope, no one has anything good for that nor any way to program it yourself.Ben
where are you gonna buy a chip when your computer doesnt even have a removable chip?Ben
i got the rare 3100v6- its a OBD-1 but its wired for a OBD-2 and it has a removeable door on top of the pcm. so if a chip is not in there what is?Thomas Herring
That is the knock sensor filter circuit.-Brad-
you should check out racetep.com because they have a programmable computer that they make for a gm cars. you just plug it into the harness where the old comp was and then hook up a laptop and use data links to tune it.95 GP with a 3.1/3.4 hybrid,custom exhaust(sidepipes)also have custom interior.Over 300 horse.
Haltech E6GM... not exactly a plug and play setup, as a few people on here can attest to. And it definately won't just plug in and run a 3100.-Brad-
