I've wrapped up the mechanical and wiring on my LX9 swap (formerly 3.4 dohc).
This is in my Grand Prix with 5 speed.
I am using a bin for a 3500/5spd but it isn't running the best. I am using the 3.4 dohc injectors. From what I can smell the motor is running rich.
Here are a few TunerProRT recordings: tunerprologs.zip
Once you unzip the names of the 3 recordings will correspond to the below,
Cold idle, Open Loop
Motor hunts for idle, smells rich, if you rev it will stall when it comes back down to idle.
It fires right up first try, but if you turn it off or it stalls it will not start without a generous amount of throttle.
Warm idle, Closed Loop
idle is stabilized. I tried to move the car just a foot or so by easing the clutch out and it stalled. The idle torque seems low. It revs smooth and does not stall. It blows some very rich smelling smoke when revving. Fires up instantly if turned off or stalled.
Hot idle, closed loop
coolant temps are up to running speed. It no longer hunts for idle or stalls. It revs nice and smooth but it still seems to blow smoke (rich) when revving
Looking for any input. I have the hardware/software to burn bins but not much knowledge on what to change. I'm looking for tuning advice, what to change, etc. OR if there is someone that would like to long distance tune I can pay. This would consist of me sending datalogs, you making changes to a bin, me burning the bin and datalogging again then sending to you and so on until we get it right.
Thanks,
John
Thanks,
John
