How do you reset an OBDII ECU to make it relearn
  • 2.8/3400 1985 Camaro
    • Nov 2009
    • 192
    Title says most of it...how do you reset an OBDII ECU to relearn driving habits and idle?
    Does resetting codes also reset the above?
    http://www.cardomain.com/ride/390342...evrolet-camaro
    • 13507
    It doesn't really learn driving habits and I am not sure there is a relearn procedure for idle other than driving the car and letting the fuel trims get sorted out if that is the issue. It doesn't self tune other than fueling, which is reactionary, meaning not the best results.
    • z34phoenix
      • Jun 2005
      • 469
      yep what ben said. but if you still want to go ahead and wipe its memory, pull the battery for about 30 min to an hour. that will do it.
      • heysoundude
        • Nov 2016
        • 16
        I pull both battery cables, jumper them together, and KOEO for 10-15...then, I found this attached document with some other ideas/suggestions, and a website that suggests there is indeed a GM-designed re-learn procedure gm drive by wire cleaning procedure.pdf
