OBD1 question
  • GreenBeast
    • Apr 2011
    • 12
    OBD1 question
    I know the OBD1 system isn't engine specific as long as the engine remains under the same guidelines as the OEM engine. I would like to swap my 3.1 for a 3.4 from the same generation and try to find it as pushrod instead of a DOHC for wiring harness purposes. Will my OBD1 system operate a 3.4 even tho the OEM application is a 3.1?
  • ericjon262
    build it.
    • Jan 2010
    • 2218
    you'll need to have a chip burned, but yeah, it should run it no problem.
    • GreenBeast
      • Apr 2011
      • 12
      So I can't just plug n play the 3.1 E.C.M to the 3.4 and it run? If I have to get a chip burned it seems easier and cheaper to just get a 3.4 E.C.M
        • 13531
        seems easier to leave your car alone and also cheaper. Its certainly far more realistic than finding a unicorn (gen 2 3.4 computer).
        • ericjon262
          build it.
          • Jan 2010
          • 2218
          we need more info here, year make model ect.
          • GreenBeast
            • Apr 2011
            • 12
            My car is a 1994 Pontiac Grand Prix SE 4 door with the 3100 and the 4T60-E tranny.
            • GreenBeast
              • Apr 2011
              • 12
              yea it kinda seems that way. Hell I cant do anything to that car it seemsClick image for larger version
