EGR delete/shutoff @ the ECM?
  • thetruckster
    • Aug 2015
    • 9
    So, can the EGR be deleted and or shut off at the ECM? If yes, approximately up to what model year? Oh, pushrod engine.
    Sent from my SM-N910V using Tapatalk
  • GhostGALA1
    • Jul 2015
    • 11
    Using HP Tuner I was able to completely delete the EGR in a 2004 Grand Am (LA1). I ended up using the EGR pintle position signal as a wideband O2 input for dataloging and tuning. Engine runs great and doesn't run any hotter than before!
    • thetruckster
      • Aug 2015
      • 9
      Your combustion chamber temps will be higher. But that's good for a cleaner, more complete burn and NOx should go down. May even see a bit of mpg improvement.
      • GhostGALA1
        • Jul 2015
        • 11
        Now that you mention that I went back and looked at a few datalogs. The engine temps are up a few degrees. This would indicate a rise in combustion chamber temps as you mentioned. Still only gets up to 105/107°C sitting in a drive thru for 5-10min @ 32°C (ambient temperature). With my ram air the IATs hit 45-50°C at those same temperatures. I know before I added the ram air it could creep up north of 60-70°C at stop lights.
        I have seen an increase of 50km/tank. Wasn't sure what to attribute that to. Could be a number of things, along with the EGR delete. Thanks for the information.
        So what year ECU/ECM do you have? and do you have access to any ROM editing/ECU flashing software?
        • thetruckster
          • Aug 2015
          • 9
          No prob. Things I been learning while being around diesels.
          I don't currently have a 60°V6. Just asking key questions before I buy.
          About a decade ago I used to be a reg around here. Knew one of the brass around here. But that was a lifetime ago. Don't even remember my old sign in stuff.
          No, I don't have any flashing software. I counted on others for that.
            EGR does not increase a gasoline engine's combustion temps or end-result EGTs.... it causes both of them to be lowered significantly, which causes less NoX to be generated.
            • GhostGALA1
              • Jul 2015
              • 11
              Agree 100%. That's what we are both saying.
              We are saying that if you were to delete the EGR, the combustion temps will increase..... Slightly!
                • 9175
                Who'd you know? Most of the brass are still here, just not as active...
                • thetruckster
                  • Aug 2015
                  • 9
                  Ben, SappySE
                    • 9175
                    Oh yeah, Ben is still around and still running WOT-Tech.
                    • thetruckster
                      • Aug 2015
                      • 9
                      Oh ok. Not familiar with WOT-Tech.
                        • 9175
                        • thetruckster
                          • Aug 2015
                          • 9
                          <<<<Ben too.
                          • thetruckster
                            • Aug 2015
                            • 9
                            So, how new can I buy and still do, or have done, ECM tunes? I'm thinking a 3400 because I'm not familiar with anything newer.
