Using HP Tuner I was able to completely delete the EGR in a 2004 Grand Am (LA1). I ended up using the EGR pintle position signal as a wideband O2 input for dataloging and tuning. Engine runs great and doesn't run any hotter than before!
Your combustion chamber temps will be higher. But that's good for a cleaner, more complete burn and NOx should go down. May even see a bit of mpg improvement.
Now that you mention that I went back and looked at a few datalogs. The engine temps are up a few degrees. This would indicate a rise in combustion chamber temps as you mentioned. Still only gets up to 105/107°C sitting in a drive thru for 5-10min @ 32°C (ambient temperature). With my ram air the IATs hit 45-50°C at those same temperatures. I know before I added the ram air it could creep up north of 60-70°C at stop lights.
I have seen an increase of 50km/tank. Wasn't sure what to attribute that to. Could be a number of things, along with the EGR delete. Thanks for the information.
So what year ECU/ECM do you have? and do you have access to any ROM editing/ECU flashing software?
No prob. Things I been learning while being around diesels.
I don't currently have a 60°V6. Just asking key questions before I buy.
About a decade ago I used to be a reg around here. Knew one of the brass around here. But that was a lifetime ago. Don't even remember my old sign in stuff.
No, I don't have any flashing software. I counted on others for that.
EGR does not increase a gasoline engine's combustion temps or end-result EGTs.... it causes both of them to be lowered significantly, which causes less NoX to be generated.
Sent from my SM-N910V using Tapatalk
Who'd you know? Most of the brass are still here, just not as active...
Discover innovative automotive software and technology solutions at Wide Open Throttle Technologies. Contact us for expert support and products for vehicle enthusiasts.
