winbin
  • 88jbody
    • Aug 2004
    • 30
    winbin
    Where can I find a .ecu file? I have several bins but can't get in and edit them without the .ecu file
    I have my gmpcm all running but I am waiting for my chip burnner just ordered it, so I'm just pre-making a few bin's
    88z24 with a 91 3.1 , 3 speed auto
    any help would be great!
    • 13531
    If you have GMPCM, why are you looking for winbin? Are you using 91 code or 88 code? 91 uses A1 which GMPCM already has.
    • 88jbody
      • Aug 2004
      • 30
      Just getting started and was going to try them both out
      I'm not concerned what code I use, I'm changing the cam and posibly a bigger throttle body with a 3100 heads and intake.
      The a1 code should work with this then, just wondering if there are any better ones
        • 13531
        Thats the best one to use. You will probably need to change the speedo code but that should be about it if you are using the digital EGR.
        • 88jbody
          • Aug 2004
          • 30
          Thanks alot
