3.1 chip on a 3100 motor?
  • blackbombshell95
    Kaiō-ken X 10
    • Jun 2004
    • 1386
    ever heard of this concept? will it work. using a 3.1 grand prix comp on a 3100 motor??
    02 GTP - 90* > Failboat
    www.blackbombshell95.com
    • 13500
    Yup, it definetly works cause ive tuned 2 gen 3s using the older computer. I dunno which year 4T60-E you would need to have though or if your 95 trans will work ok with some wiring changes.
    • 88jbody
      • Aug 2004
      • 30
      swap to a 5speed and the trasmission problem is solved
        • 13500
        Swapping the 5 speed is considerably more work than finding out if the wiring can be redone to the trans to work, especially in a 94+ w body.
        • blackbombshell95
          Kaiō-ken X 10
          • Jun 2004
          • 1386
          i would love to have a manual. but i can'nt find anybody to do it . lol. i have a 95 grand prix... so how well will an older computer work with my tuned car??? how hard would it be to install an older computer?? i'm sure an older TGP computer will work well especially if i get a turbo huh??
            • 13500
            Same computer as the NA 3.1s (w body). However the TGP computer wont work with your trans unless you wanna let the stock ECM handle the transmission crap (though adjusting shift points is very nice). Aside from wiring it up, it will work out just fine once you tune the chip in the computer.
            • blackbombshell95
              Kaiō-ken X 10
              • Jun 2004
              • 1386
              so would i need two computers with a turbo setup??? is that possible. is their anyway to program a 3.1 computer to work my my trans? there is a guy who makes turbo grand prix chips, in fact he owns seVERAL turbo grand prixs. he is JIM at www.turbograndprix.com i'm sure with his knowledge he might be able to get my trans to work with the older computer if it is possible.
                • 13500
                If you use the 3.1 with 4T60-E computer (same as 91-93 DOHC) then its a possibility. Im just not sure how the 95 trans works compared to the 91-93. I know its different but how much so and what the computer cares about are what are important.
                • blackbombshell95
                  Kaiō-ken X 10
                  • Jun 2004
                  • 1386
                  who might know that answer ben?
                    • 13500
                    Brad might know.
                    • blackbombshell95
                      Kaiō-ken X 10
                      • Jun 2004
                      • 1386
                      what if i do this. since im planning doing a turbo swap from a 3.1 . and i will have to use a turbo grand prix pcm, how about i use a turbo grand prix tranny? won't that work with my car?
