car acting stupid
  • geldartb
    The Situation
    • May 2004
    • 1994
    car acting stupid
    ok to start off with a couple weeks ago my car started acting stupid like it would almost die out on me when i stepped on the brakes or put any electrical load on it so thinking it was the battery i swapped it out with a brand new one that seemed to fix the problem for a couple of weeks the yesterday driving down a major road i stepped on the brakes and my car almost shut off on me it killed it enough to reset the radio and everything. today it did the same thing except i didnt hit the brakes im just driving along and the speedometer starts jumping all over the place hit the gas it goes back to normal. after this happened i decided to go back home before i killed someone or myself on the way home i hit the directional so i could turn the car almost dies shut the siganl off its fine. what could be causing this bad ground or a shitty computer any help is appreciated
    99 Grand Am GT
    1357 cam 227 233 .050 dur
    515 515 lift 112 lsa
  • Anonymous
    If your gauges are moving around, I would DEFINATELY change the alt. The day my alt when bad, every gauge my car has started acting all funny. The rpm gauge was the worst.
      • 13533
      Sounds like alternator issues to me. An IAC isn't gonna kill the power and make your gauges act stupid.
      • geldartb
        The Situation
        • May 2004
        • 1994
        95 beretta z26 i had the injectors cleaned and serviced awhile back they said they were pretty clogged up but they were still fine cause i told them that i was gonna buy some new ones and there like there fine and my iac is about a year old and has about 30k on it everything else is pretty much brand new
        99 Grand Am GT
        • geldartb
          The Situation
          • May 2004
          • 1994
          the alternator is like a month or 2 old should piss throught them that quick
          99 Grand Am GT
            • 13533
            What brand is it? Ive seen them go bad in weeks. AC delco or nothing in my book, mostly cause my alt is under my motor. It could be a ground wire somewhere though, or a poor connection at the alt/starter/battery.
            • geldartb
              The Situation
              • May 2004
              • 1994
              think i found the problem the big bolt on the bottom of the alternator was half hanging out and the nut was missing and the alt was loose
              99 Grand Am GT
              • geldartb
                The Situation
                • May 2004
                • 1994
                its a napa
                99 Grand Am GT
                  • 13533
                  Napa should be good, but ive never used one. If the alt was loose and the belt was slipping on it, then thats gonna be the same as a bad alt:P Glad you found the problem (hopefully).
                  • geldartb
                    The Situation
                    • May 2004
                    • 1994
                    glad you said something about the alternator cause i would have never checked it that couls be why it only happened when i stepped on the brakes must have shifted the engine enought to make the belt slip. thanks for the help you guys saved me from tearing it apart and pissing a day away trying to find the problem hopefully this solved it now i just gotta go get some wheel bearings and ill be all set for a litlle while.
                    99 Grand Am GT
