change memcal -MAF to MAP?
  • Anonymous
    I was wondering what the deal is with changing the memcal on the '88 2.8 engine. If I understand correctly, to change from MAF to MAP you change the memcal chip to one from a 3.1L that has a MAP sensor?
    Which brings the next question, I don't know anything about MAPs, so how do you wire/bolt on that thing? I've been trying to read up on this stuff but still have questions that have probably been asked before.
    Thanks guys
    ps. I'm not sure if this is in the right section .. move it to the pushrods if you want.
    • 9191
    This section is fine....
    As far as the MAP goes, you already have one bolted up. MAF cars actually use both a MAP and MAF, but the MAF is the primary. As far as the PROM goes, there is a specific PROM out there I think for this particular swap. It is direct from GM. I know you can't just take any 3.1L PROM and swap it in. Ben might be able to hook you up with a PROM for a decent price.
    • Anonymous
      So is there no recall for this specific problem?
      Yeah, I'd like to get that damn SES light off, and maybe be able to pass the e-test next time.
      So the 3.1 PROM doesn't work, but what if you were to swap the MAP as well (if there is a difference). I'd rather go to the wreckers and pull the junk out than pay for new stuff. Oh well whatever works (and doesn't break!)
        • 9191
        The wreckers will probably charge you about as much as Ben would...
        • Anonymous
          The wreckers are stupid too.. they'd probably give me the same one I already have
            • 13531
            I cant just erase the stock prom...and I have 2 eeproms left which I need to sell in the perf chips so I can afford to buy more.
            Its a 2.8 chip that uses the MAP sensor...thats all you need. You may be able to find one at a junk yard. ASWH is the chip you need if you have a 4 speed auto.
            • Anonymous
              Thanks Ben. I'll take a look and see what they got at the wreckers later this week and tell you how it goes.
