Help with ecu file?
  • v631lumina
    • 4
    Help with ecu file?
    Hi, I'm new to tuning and I was wondering where to find an .ecu file for a 90 lumina chip. I looked at the eeprom and it had AUMX 1249, which I found a bin file for. It also has 6J0134 and delco J733. What is the A1, 6D, 88? I'm confused, I understand that they are different layouts, although do I just pick one or is there one particular for my vehicle? So I have the winbin setup and the bin file if that is right, which ecu file do I use and where do I find it.
    thanks
    aric anderson
  • ryan.hess
    • 526
    what ECM? the 7727?
    Okay now, that's enough of that.
    • v631lumina
      • 4
      where do I find that? Here is the info from the bin lookup:
      Broadcast Code Year Release Date EPROM
      AUMX 1990 1989-12-12 16151248
      ECM Prom ID Scan ID Platform
      16197128 1249 1301 WB
      Engine Displacement Transmission Transmission Type
      LH0 3.1 ME9 AUTO
      Gear Ratio Emissions Contributor Get Bin
      Aumx1249 5F.bin
      ecm 16197128
        • 13525
        90 code is 88 mask. If AUMX is 5F, its for the MAF sensor and there isn't much you can do for tuning that other than tunercat (maybe). I would go with the update chip to remove the MAF from the engine.
        • v631lumina
          • 4
          do u mean the mass air flow sensor because I don't have one? All I have is a map sensor and the iat. I was just trying to disable the egr.
          thanks
          anyways
          aric
