3100 EEPROM/MAF computer '95 era, A-body
  • Rhedalert
    Dr. Feelgood
    • 1574
    I searched a little but haven't come up with much. Has anyone looked further into using this computer, or has anyone tried converting to it?
    Brian
    3400 SFI V6, 4T60e
    • 13533
    tunercat has a setup for it now. Someone on this board is using but but I haven't messed with it at all. That and tunercat is like 70 bucks or so. Id probably convert to OBD2 in your situation.
    • Rhedalert
      Dr. Feelgood
      • 1574
      Oh yeah I haven't ruled out OBD2, but the more I look into the conversion, the more of a PITA it looks like. I may have to lay the car up for several days, which isn't easy lately.
      Brian
      3400 SFI V6, 4T60e
        tunercat can tune the odb1.5 95 crap? Interesting... Is it for A body only though?
        • Azrael
          Accelerating uphill in OD
          • Apr 2005
          • 763
          There was at least one GM car in 95 that had a tuneable ECM...I think it was from a buick.
          1995 Grand Am SE
            ah that's right it had a removeable chip w/3100. I can't remember who tried to adapt that..
              • 9191
              3400-Modified did it. Not sure if he ever got everything worked out. I have one of the ECMs sitting in my basement. Just never got around to messing with it...
              • geldartb
                The Situation
                • May 2004
                • 1994
                what model buick had the ecm with the removable chip in it. or was it just buick for that year in general.
                99 Grand Am GT
                1357 cam 227 233 .050 dur
                515 515 lift 112 lsa
                • 95SleeperAcheiva
                  ArtofOlivia"PocketRocket"
                  • Jun 2006
                  • 694
                  Hey Hey Hey! I want in on this! I've got too many plans and I'm about to be stomped if I can't get this damn ecu re-burned, lord knows how many times till it's right....
                  Isaac, Buick and Olds ussually go hand-in-hand when it comes to wiring and ecu's. I'll pull some part numbers from the factory tom. and see what we got. BRB
                  • geldartb
                    The Situation
                    • May 2004
                    • 1994
                    if anyone can find out before tomorrow midday im going to the junkyard so ill pull what i can find.
                    99 Grand Am GT
                    • TurboGTU
                      • 453
                      94-95 buick century. The thing looks like someone did a 3100 swap where a 3300/3800 used to be. The whole setup is simmilar. Maff setup, wring and all.
                      Code looks 3800ish to me.
                      ONly thing this thing is good for is SFI and trans controll. BUT what style of trans setup? INternal electrical setup of the 60-e changed around that year. SFI...who needs that anyway unless your looking at big power but you also need a bigger maff...which one to get? Not worth it to me.
                      You'd be better off with a auto TDC ecm if your looking for electronic trans controll for your auto powered little hot rod.
                      • geldartb
                        The Situation
                        • May 2004
                        • 1994
                        would i need the wiring harness from the car or is this mor or less a plug and play type of thing. OT the upper intake is different on theses cars too its got a 3800 ish type of throttle body setup. i snagged the computer and the othe box that sat ontop of it.
                        99 Grand Am GT
                        • TurboGTU
                          • 453
                          Yes..you need the wiring harness and the maff meter.
                            Turbo: not only do we need trans control, but some way to tune our bastard gray year ODB1.5 whatever crap.
                            • 95SleeperAcheiva
                              • Jun 2006
                              • 694
                              All the buicks of 95, except the century, have a the same plugs as our grey area nightmares. 3 32-pin connectors. The century has 2 32-pin and 1 24-pin connector, and they look really differant in their pics. It might be possible to just do a connector switch by knocking out the pins and putting them into the right holes on the proper connector blocks. I'm looking for the factory part numbers now to the century connectors. Then all we would have to do is add a few wires for the MAF.
                              12045575 Black 32-pin
                              12047946 Black 24-pin
                              12045471 Orange 32-pin
                              Now where do I get a 65mm MAF for a 95 Buick Century so my 3400 can breath?
