27SF512 to replace 29c256?
  • sil
    4T60-E killa
    • Nov 2004
    • 723
    over at moates they are selling the sf chip and they state that its a direct replacement.
    is that really all you need to do is change the start address to hex 8000 when burning your bin.
    and change some dips on your willems to set a different erase voltage?
    i have a couple of these chips and i think it would be greate to be able to use them.
    i think i want to pick up a G1 adapter as well hehe
    • 13531
    Yup, that is the chip im using now. I dunno on the willems burner as I use the moates but it sounds like what you need to do.
    • sil
      4T60-E killa
      • Nov 2004
      • 723
      score
      hey did you ever find chris' bin, we were talking awhile ago and you said my setup was really close to his
      2.8 crank/block
      3100 topend (small runner i think)
      stock fpr
      3100 injectors
      496 lift
      N.A
      3.73 gear ratio
      im so close to tuning, i need to install my new plugs, knock sensor, o2 sensor and see if it will go into closed loop
      wasnt going into closed loop last fall before i parked it..
      hopefully i will have some datalogs soooon
        • 13531
        I dont know where his modded bin file is but he may still have an old copy of it.
        • sil
          4T60-E killa
          • Nov 2004
          • 723
          ic ic, im just concerned about the spark tables
