Can someone check this out...
    Lemmie know if you see anything strange. I'm still having some idle issues when the VSS reads 0 (RPM drops and car dies). this is a log with an adjusted version of a retail chip (not at liberty to say which one).
    This is an internally stock 3.1 5 spd (that i know of) with a nasty exhaust leak, no cat and a bunch of odd wiring issues.
    I can attach the bin if anyone wants it.
    thanks,
    Dave
  • sil
    4T60-E killa
    • Nov 2004
    • 723
    was that chip thats been adjusted from an auto ?
      nope, it's made for a 93 5 spd
      the only things i changed in the chip so far were the fan on/off temps. the chip had them quite a bit lower than the stock thermostat.
      • moonwell
        V6Z24
        • Feb 2006
        • 53
        You have this problem with the stock chip? Which chip are you running exactly?
        Odd things I see after a real quick look...
        The injector BPC is way higher than it should be in many areas. You're hitting 10-11 at WOT which shouldn't happen on a stock motor. Getting some knock at WOT as well. BLM's are still showing on the rich side though. Clogged fuel filter maybe? Partially clogged injectors?
        O2 crosscount seem a bit spuratic. I'd probably replace the O2.
        Car is dying because the IAC counts are dropping too low... IAC value seems a bit high at idle to begin with (around 35), so maybe try adjusting the throttle screw to bring those IAC counts down to 15 at idle & it will probably solve the stalling problem.
        V6Z24.com
          the chip is one that i aquired from you (well the .bin atleast) a few yrs ago.. remember the one that had 11 changes from the stock #A1
          attached is a log with the original chip installed. It ran much worse with it.
          I'll see if i can find another o2, i know where my heated one is but i'm not putting that on this car. lol
          At lower RPM's while crusing it cuts out, spudders etc... seems to lack power as well. It's been a while since i've driven a 3.1 though... lol
          • MATT2007
            • 127
            hay superdave you going to high school wars at cordorva in the spring I am and hoping to have my car painted by then I am going with a bunch of idiots that think ther 2.0 leater accord and 1.5 leater crx are fast
              • 13500
              yeah, that could be pmed to him as that has absolutely nothing to do with computer tuning.
