3.1 chip
  • 3.1cutlass
    • Feb 2007
    • 101
    3.1 chip
    Ok i have a 91 cutlass supreme sl and they dont make anything for my car. But i found a chip that fits a 91 grand prix 3.1 will it work in my olds?
    • 13531
    Who? I have a chip on the store here that I did from dyno tuning. I am not aware of anyone else with a chip for these vehicles that does anything close performance wise.
    A 3.1 chip for a 91 grand prix will work for a 91 cutlass.
    • 3.1cutlass
      • Feb 2007
      • 101
      It was made by superchips.
        • 13531
        Yup, used to have one of those. Don't waste your money. Stock is as good as that chip performance wise.
        • 3.1cutlass
          • Feb 2007
          • 101
          so does the chip sold on this site work?
            • 13531
            Yes, it is dyno proven. Guess no one else wants to reply that has one of these chips.
            • 3.1cutlass
              • Feb 2007
              • 101
              guess not. I will have to pick one up when i do my turbo install in te spring.
                • 13531
                You can't use an NA chip for a turbo setup.
                • TurboSedan
                  • Jun 2004
                  • 218
                  Kenny (TGPilot) sells Turbo 3.1 chips, he is the site admin on tgpforums.com and owns KAZ MotorSports. his chips are dyno tuned using a DynoDyamics dynamometer. i went from a Jeff M TopGun chip (an aftermarket TGP performance chip) to his KAZ tuned chip and gained roughly 30whp & 35wtq from EEPROM (chip) tuning alone.
                  '91 Cutlass Supreme sedan - 3.1 Intercooled Turbo / Getrag HM-282 5-speed - 13psi / lightly modded
                  '98 Regal GS - 3800 Series II Supercharged/HM-4T65E-HD - 180* T-stat, otherwise stock
                  GM W-body Forums
                    • 13531
                    Did you dyno tune your car or was it a chip that was sent to you without using any datalogs? Just curious.
                    • 3.1cutlass
                      • Feb 2007
                      • 101
                      Ok thanks alot guys for your help
                      • TurboSedan
                        • Jun 2004
                        • 218
                        i actually went down to Colorado Springs and had the car tuned while on the dyno. i think Kenny used a Moates Ostrich emulator and TunerPro RT to do the tuning and datalogging.
                        he's tuned his own TGP/5-speed this way (which put down dyno #s very similar to my car at both DynoPros (DynoJet) and his own shop as well as his Grand Prix Turbo STE (automatic). i think his Turbo STE went 14.698 @ 93.19 with 2.2 60'. pretty impressive given the altitude and short mod list.
                        Originally posted by TGPilot
                        No knock at all with 3.5 gallons of 100 proof mixed with probably 2 gallons of 91 pump gas. at nearly 6000ft elevation with the only mods being cone air filter and chip tuning.
                        GM W-body Forums
