what files do i need?
  • Alxsmt
    that one guy
    • Feb 2007
    • 725
    well i have an 88 beretta 2.8 (well 3400) 5spd, ECU # 01227730
    what files do i need to tune with tunerpro? and data logging? what is the file type for both of them? im still learning about this stuff, so go easy on me! lol
    • 13531
    I would try the BFUZ.bin file with the A1 xdf file in tunerpro. Im not sure on a file for scanning with tunepro as I use freescan (do a search for freescan). 410b def file in freescan (drop down box).
    You will need to change the code for your EGR (flag, set to vacuum, not digital) and the speedo code, divisor and pulse per mile. Copy those off your stock chip. Stock code is 6D which is not supported too well. You will have to look in the hex code for a pattern and see where the divisor and ppm is. That or someone may have it written down.
    • Alxsmt
      that one guy
      • Feb 2007
      • 725
      ok, i will start from there! thanks man
      • Alxsmt
        that one guy
        • Feb 2007
        • 725
        well i got freescan, it says it cant find the specified file... i downloaded i twice to make sure it just wasnt corrupt
          • 13531
          specified file? Im confused. It won't decompress?
          • Alxsmt
            that one guy
            • Feb 2007
            • 725
            not, like when i open the program, i can see all the features it has and stuff, but i just wont load any of the ECU files or what ever im guessing
              • 13531
              Im getting the same thing (just reinstalled it). Well this is lame.
                • 13531
                haha, ok, figured it out. Select the com port first and then load the 410b file.
                • Alxsmt
                  that one guy
                  • Feb 2007
                  • 725
                  lol sweet, i will try that!!
                  • Alxsmt
                    that one guy
                    • Feb 2007
                    • 725
                    ok it "worked" but still not reading anything... i even tried my friends scan tool, it couldnt connect to the vehicle or something, it was weird
                      • 13531
                      is it set to interact? 50ms delay. Hit Force Data. if it doesn't move, hit it again. Both numbers should be moving.
                        • 13531
                        btw, you can't use your stock chip with that.
                        • Alxsmt
                          that one guy
                          • Feb 2007
                          • 725
                          what do u mean i cant use a stock chip?
                          i will try that tomorrow though
                          thanks
                            • 13531
                            Your stock chip is not A1 mask, which is what that code is for (and works for 91-93 DOHC as well). If you are using BFUZ now, then its fine.
                            • Alxsmt
                              that one guy
                              • Feb 2007
                              • 725
                              so whats different about bfuz file then the stock 2.8 file?
