am i set?
  • Alxsmt
    that one guy
    • Feb 2007
    • 725
    am i set?
    ARYC.BIN and A1.xdf in tuner pro rt
    7730 ECM, 88 beretta with magnetic speedo (i thing thats what it is)
    • 13520
    no, an 88 beretta uses 6D. Start with BFUZ and change your EGR type in the flags, and the VSS/speedo code near the beginning of the .bin. Then you will have A1 compatible code setup for your vehicle.
    • Alxsmt
      that one guy
      • Feb 2007
      • 725
      with that i can still use the A1.xdf and A1.ads correct? and just swap those 2 things over?
      • Alxsmt
        that one guy
        • Feb 2007
        • 725
        what about the speed density?
          • 13520
          Yes it runs MAP, no MAF and yes, that allows you to use the A1 files.
          • Alxsmt
            that one guy
            • Feb 2007
            • 725
            ok, i guess thats good. my aldl cable isnt connecting
              are you sure the wires are in right?
              you'll need the $A1 bin uploaded to the ostrich as well...
              • Alxsmt
                that one guy
                • Feb 2007
                • 725
                yeah there in right i think. i can slide the switch on the side of the aldl box and get the fan to turn on and get the engine codes. btw does that matter what setting its on?
                i have your A1.bin, is that the same as $A1.bin? so upload 2 files?????
                  you shouldn't be able to get the fan to turn on, that only happens when you connect pin B to A..
                  A is ground, M is the datastream...
                  open up tunerpro, select the $A1 .xdf file.. then open up the BFUZ binary file. make sure the Ostrich is connected (you may have to go to Tools > Initialize attachesd hardware.. at the bottom of the tunerpro RT window it'll tell you weather or not you are emulating and also if you are connected to an emulator or not. Once you are sure it's connected then click the blue up arrow and upload the BFUZ bin to the emulator.
                  check and make sure the car starts.. and isn't in limp mode (fan on and CEL).. then connect the ALDL circuit and try to datalog.
                  • Alxsmt
                    that one guy
                    • Feb 2007
                    • 725
                    tried it again. same thing....
