tuning for bigger injectors?
  • Alxsmt
    that one guy
    • Feb 2007
    • 725
    ok well i read the tutoral on bstuff.com for a turbo gp code but i can only do the idle (i dont have the other things to change?) i also cant get it do idle at all with my bigger injectors in
    what exactly do i need to change?
  • Joseph Upson
    Originally posted by Alxsmt View Post
    ok well i read the tutoral on bstuff.com for a turbo gp code but i can only do the idle (i dont have the other things to change?) i also cant get it do idle at all with my bigger injectors in what exactly do i need to change?
    Not sure what you found on Beretta com and I wasn't about to join the forum in order to gain use of the search engine. Try this thread, it should help;
    ****DISCLAIMER***** I will not be held responsible for any damage, at all, whatsoever that may result from you trying to tune your car. Read the entire how-to, several times, before even attempting this. ******************* This how-to is for anyone that has a turbo 60V6 with a GM OBD1 socketed...
    • Alxsmt
      that one guy
      • Feb 2007
      • 725
      the same guy posted that on bstuff.com, i think in my xdf its just not called the same same thing or something cuzz i dont have anything that he mentions other than BPC vs. Desired EGR% and i cant even get my car to idle with that and my injectors idle may be another problem but it likes to pulse and stutter when im driving and it doesnt do that with my other injectors
        to adjust for larger injectors you change the 0% value in the "Base Pulse Constant Vs. Desired % EGR" table.
        That's the global constant, the stock 3.1 BPC is 224 for 16# injectors.. I have it set to 150 for a friends cammed 3400 running #24 injectors and mine is set to 129 to run the 36lb injectors.
        After you change that then you'll have to work over the VE adder table first.. then fine tune the main VE vs RPM vs MAP table.
        • Alxsmt
          that one guy
          • Feb 2007
          • 725
          ok cool, so how do you determin how to change what value to what after you do the global? or is it ovious by just lookin at my wideband and BLMs?
          i just noticed the idle VE vs RPM vs MAP. because my car seems to have an idle issue, do you think i could fix that with this table? if so how would you go about doing that?
            since everything is affected by the BPC i'd get that right first.
            What size injectors are you using? (i forgot)
            • Alxsmt
              that one guy
              • Feb 2007
              • 725
              they are 28# from the I6 trailblazer engine
              so should i be able to get it driveable by just changing the BPC? i couldnt get it after about 45 mins of messing with it, hell my AFR didnt even really change much according to my gauge and the BLMs prettymuch stayed the same too. i started at 150 on the bpc and went clear down to 40 too. i have a better idea on where it should be now
                I'd say 140 should work.. then see where that takes the BLM's.
                • Alxsmt
                  that one guy
                  • Feb 2007
                  • 725
                  ok i will set it at 140
                  • Alxsmt
                    that one guy
                    • Feb 2007
                    • 725
                    also, how do i tell if my injectors are maxed out?
                    im going to go play around with the fuel on my stock injectors to get a feel for it
                      It's a calculation.. I usually add it into excel when i'm viewing datalogs.
                      Injector duty cycle = PULSEWIDTH / ((60 /RPM ) * 1000) * 100
                      you don't want to go over 80%
                      • Alxsmt
                        that one guy
                        • Feb 2007
                        • 725
                        ok i dont get the last part of that lol
                        1988GTU pointed me to www.GMtuners.com and i may send them an email if i cant get this figured out on sunday. my data logger keeps freezing up my computer and its really pissing me off. if nothing else i can use there tune as a baseline for a local shop
                          so what is your exact combo in the car right now that you are tuning?
                          • Alxsmt
                            that one guy
                            • Feb 2007
                            • 725
                            what do you mean?
                              engine wise.. stock 3400?
