tuning for bigger injectors?
  • Alxsmt
    that one guy
    • Feb 2007
    • 725
    oh,
    -3400 5spd
    -2.5" mandrel bent exhaust with mangaflow muffler and cat
    -modified and ceramic coated s&s headers
    -3500 topend with cc match and polished combustion chambers
    -fresh 3 angle valve job
    -indexed plugs
    -cyrogenic treated rods
    -tce 65mm throttlebody
    -ostrich ECU emulator
    -innovate LC1 wideband
    -1393 cam regrind
    -comp cams springs
    -parelled block
    -ballanced
    -JE 10.5:1 pistons
    -28# injectors (not installed yet)
    the data log you looked at was from this engine
      ok, in that case get those 28 lb injectors installed ASAP .. LOL
      • Alxsmt
        that one guy
        • Feb 2007
        • 725
        yeah i know lol. does that data log make sense at all now?
        • 1988GTU
          LB62LHObbqftmfw
          • Nov 2005
          • 2475
          That company will keep retuning for FREE once you paid for the chip/tune once. All you must pay is shipping costs. So it would probably be beneficial for them to finish tuning it instead of paying a shop hundreds more to finish it up.
          • Alxsmt
            that one guy
            • Feb 2007
            • 725
            yeah but i just dont like the idea of a perfect tune with out a dyno or some1 being in my car with a laptop
            but for that price it would be well worth it to me for just a better starting point
            • 1988GTU
              LB62LHObbqftmfw
              • Nov 2005
              • 2475
              #21
              I would think that if you had a real professional (someone that knows these GM engines) tuner sending you a chip there would be very little need of a dyno UNLESS you just want to see some graphs and have printed proof of you power output. Although you could just take it to the track after its tuned to pretty much figure that out.
              You have a wideband already, you can log now, then with a good tuner it should all fall into place. I bet with 2-4 tries from sinister it'll be 99% perfect and the dyno really wouldn't be needed.
              Have you talked with them yet? What they say?
              • Alxsmt
                that one guy
                • Feb 2007
                • 725
                #22
                i emailed them about getting a base tune with it setup for my injectors and they said with out my datalogger working there wouldnt be a warrenty or something like that. but im cleaning the hell outa my laptop thinking maybe it will work with the tuner pro datalogger. if not im downloading the program you sugested or i may just download it no mater what
                with a datalog i may just have them do there best, then take it and dyno it myself but we will see how far i get on sunday
                  there is no such thing as the perfect tune..
                  It's going to take a few weeks of work but you have all the tools to get it done, I probably have a base tune you could start out with.
                  • Alxsmt
                    that one guy
                    • Feb 2007
                    • 725
                    #24
                    well im ready to test my datalogger again on tuner pro.. i hope it works!
                    also with datamaster, will the tgp one work?
                    i know i have the tools (if my datalogger works) but i dont exactly have the knowledge yet. its slowly makng sense tho thanks to you guys
                    • 1988GTU
                      LB62LHObbqftmfw
                      • Nov 2005
                      • 2475
                      #25
                      I honestly use the TGP file to log since I am boosted. IF I were you I would contact them and see what they say. It shouldn't matter, just a couple things will not be reading (like turbo WGDC for example) .
                      • Alxsmt
                        that one guy
                        • Feb 2007
                        • 725
                        #26
                        ok, i will just try it tomorrow
                        • Alxsmt
                          that one guy
                          • Feb 2007
                          • 725
                          #27
                          i got a few logs with my 28# injectors from tunerpro. its froze once but at least i got a few logs in neutral. it WILL not idle and im clueless on that. seems to be rich (high 9s) with the bpc vs egr at 140.
                          i also have to hold the petal to the floor and if im lucky it will start. after its been running and dies or i turn it off it will not start for a good hour (like maybe its flooded??)
                          it does sound a LOT healthier at upper rpms
                          i tired to drive it but it died after backing up when i was putting it in first
                          • TurboGTU
                            • 453
                            #28
                            Your using the 8f code? then 140 is too rich even for stock injectors. Set it at 50-40. Stock on the BPC Vs EGR its at 105 for the 22lbs. So if your going to the larger injectors, set it lower.
                            What code are you using A1 ??
                              $A1 code.. it's like 210 for stock injectors, 140 should work for 28lb injectors...
                              • Alxsmt
                                that one guy
                                • Feb 2007
                                • 725
                                #30
                                yeah the a1 code. i reformated my laptop and it wouldnt connect to the usb port, but i could use a desktop and a friends laptop and it worked just fine..
                                here is a current log set at 140.
                                im done messing with it becaue of the datalogger, its pissin me off too much. i sent the log to Sinister Performance and there gonna have a .bin for me to try out tomorrow or monday. then i gotta use my frieneds laptop again for a log lol
