$DF shift point higher that 6375?
  • sil
    4T60-E killa
    • Nov 2004
    • 723
    RPM THRESHOLD TO FORCE F31 TRANSMISSION UPSHIFT VS. STARTUP COOLANT TEMPERATURE
    sick of such a low shift point:P
    7k or bust :O
    how can i achieve a 7k shift point on df if this limits it to 6375....
    always shifts 1-2 at 6375...me needs higher to bring up the 2nd gear rpms
    sits at 4100 when it shifts to 2nd
    wanna bring that to around 4500
  • Guest
    You would have to develope a patch to have higher shift point.
    Most GM ECMS are limited to this 6375 RPM for most of the variables, the only one I have found that seems to be able to be set higher (IIRC I think I was able to go to 17000 RPM or so) was the rev limiter.
      • 13531
      use the MPH shift points?
      • sil
        4T60-E killa
        • Nov 2004
        • 723
        lol, i tried if ya set it to shift at a higher MPH you hit the RPM limit and it backfires, then shifts
          i may have a workaround for ya Sil... just need to have the PCM compare against a RPM X 50 variable instead of RPM X 25.
