3800 series 3 fuel pressure
  • geldartb
    The Situation
    • May 2004
    • 1994
    ok this is probably a long shot on here and dont kill me yet.
    but would anyone happen to know the fuel pressure for the series 3 3800 with the 36lb injectors, ive been looking ariound and cant find anything solid.
    i was trying to find something written up by GM you know like a detailed spec sheet of the engine as far as fuel pressure and what not goes.
    99 Grand Am GT
    1357 cam 227 233 .050 dur
    515 515 lift 112 lsa
    • 9181
    You should be able to look it up on that site. I don't know what a 3800 S3 came in, otherwise I'd look it up.
    • geldartb
      The Situation
      • May 2004
      • 1994
      it was 04+ in the grand prix and prob whatever else they stuffed the 3.8 supercharged in.
      i keep coming up with what look like hopefull leads but end up dead.
      i tried that site you posted but of course they dont go into details for the stuff i want to know
      i spent hours searching clubgp and sites like that but end up with nothing
      99 Grand Am GT
        • 9181
        There is always the possibility that they didn't use Delphi injectors in that engine, therefore the linked site not having any information.
        Did you try Witchhunter?
          • 9181
          It appears they are Bosch EV6 injectors. The Bosch website just lists them as their flowrates (in g/sec) @ 3-bar (~44psi).
          Since the Series 3 uses a returnless fuel system, and the regulator is therefore built into the fuel pump, you might be able to do a search on that to find the pressure output at the pump.
            • 9181
            That lists output of 430kPa, which converts to ~62.4psi. Say there is som pressure drop through the lines, and I'd guess you are looking at ~55psi at the rail.
            • sprucegagt
              Old School KI
              • May 2005
              • 703
              http://go.delphi.com/cs/welcome.aspx
              That site used to have the specs for there older injectors. But lately they have been removed. Now you can only get specs for the current production or very late model injectors.
              FYI, delphi injectors were used in it (or at least licensed by Bosch). Look up part number FJ10300.
              Those injectors are actually 33 lb/hr (@ 43.5 PSI). It's the increase in fuel pressure to 55 PSI that makes them run at 36 lb/hr.
              Your local OBDII moderator
              2000 Grand Am GT w/ WOT parts
                • 13499
                That would make them 42# (41.7) at 55psi.
                • geldartb
                  The Situation
                  • May 2004
                  • 1994
                  ive got an adjustable FPR so adjusting wont be a problem.
                  so with all these number what am i looking at for 55 psi at the rail. once i get it going i can drop the pressure
                  99 Grand Am GT
                  • sprucegagt
                    Old School KI
                    • May 2005
                    • 703
                    Not according to witchhunter.com. It says it would be 37.1# at 55 PSI.
