Elm327 or similar device
  • Weatheralls Auto
    Spinning out of control
    • Dec 2009
    • 536
    #76
    1 example is the getting the Vin,
    since the elm is getting extra bits the Vin returns Junk.
    I am going to work with it over the week end, remove all white spaces etc to make the calculations simpler in hopes of filtering out what is not wanted.
    As of April 2
    Engine: 2006 SV6 3500 LX9
    Trans: 2002 Getrag F23 5speed
    Injectors: #36 GTPs
    TB: 65mm TCE
    Maf: 1999 3400 Montana.
    Beverages: Ice Cold CANADIAN.
    • Weatheralls Auto
      • Dec 2009
      • 536
      #77
      Dealing with the vehicles in the shop today.
      1998 LN2 2.2 Sunfire, works perfect even while running
      2002 LN2 2.2 Cavalier, Too much chatter, can't get VIN and takes several attempts to get key process started correctly.
      As of April 2
      Injectors: #36 GTPs
      TB: 65mm TCE
      • Weatheralls Auto
        • Dec 2009
        • 536
        #78
        Just playing around today and having some fun with this car (98 Sunfire LN2 2.2)
        using Hyperterminal, I send
        ae02010000000000
        that disables #1 Injector
        As of April 2
        Injectors: #36 GTPs
        TB: 65mm TCE
        • Weatheralls Auto
          • Dec 2009
          • 536
          #79
          and AE 02 00 80 00 00 00 turns it back on
          As of April 2
          Injectors: #36 GTPs
          TB: 65mm TCE
          • Weatheralls Auto
            • Dec 2009
            • 536
            #80
            The elm has a very small buffer so its hard to monitor but possible.
            (I am monitoring my Tech2)
            As of April 2
            Injectors: #36 GTPs
            TB: 65mm TCE
            • Weatheralls Auto
              • Dec 2009
              • 536
              #81
              AE 02 00 80 00 00 00 00 Returns any Disabled injectors back on
              AE 02 01 00 00 00 00 00 Disable Inj #1
              AE 02 02 00 00 00 00 00 Disable Inj #2
              AE 02 03 00 00 00 00 00 Disable Inj #3
              AE 02 04 00 00 00 00 00 Disable Inj #4
              Question is can I turn off more than 1 at a time? lol
              Going to try
              Edit, yup can actually turn off all 4 cylinders lol
              As of April 2
              Injectors: #36 GTPs
              TB: 65mm TCE
              • Weatheralls Auto
                • Dec 2009
                • 536
                #82
                AE 01 10 10 00 00 00 00 Turn Coolant Fan ON
                AE 01 10 00 00 00 00 00 Turn Coolant Fan OFF
                AE 01 00 00 00 00 00 00 Return Control to PCM
                I seem to be having TOO much FUN lol
                add
                AC must be turned on for following commands
                AE 01 40 40 00 00 00 00 Turn AC Comp Relay OFF
                AE 01 40 00 00 00 00 00 Turn AC Comp Relay ON
                Fuel Pump
                AE 02 00 00 00 00 80 00 Turn OFF
                AE 02 00 00 00 00 80 FF Turn ON
                As of April 2
                Injectors: #36 GTPs
                TB: 65mm TCE
                • Weatheralls Auto
                  • Dec 2009
                  • 536
                  #83
                  Alt L Terminal
                  AE 01 01 00 00 00 00 00 Turn OFF
                  AE 01 01 01 00 00 00 00 Alt @ Full Duty Cycle
                  As of April 2
                  Injectors: #36 GTPs
                  TB: 65mm TCE
                    there's something that always concerned me with OBD2: the alt duty cycle.
                    if whatever controls it fails, does it revert to a 100% duty cycle, 0%, or does it go off of the internal regulator or ???
                      ae02010000000000
                      That would be funny to mess with someone you are riding with while running a scan with them driving, lol. "Dude, you've got a bad miss all of the sudden..." They freak out and you turn the injector back on, lol. BTW, Ben and I are working on a 96Achieva for a friend (3100 with the broken cam syndrome) that I can put power to and run this app to get the seed/key from it if you like.
                      • Weatheralls Auto
                        • Dec 2009
                        • 536
                        #86
                        Robert, When I "DeActive" the L Terminal of the Alt, it goes to 100%.
                        So I would think that if there is a fault it wuld default to 100%
                        PR that would be sweet, the more info I can get the better.
                        As for playing pranks, you can get the bluetooth elm devices, plug it in when ur buddy driving with out him knowing. Could have lots of fun lol
                        As of April 2
                        Injectors: #36 GTPs
                        TB: 65mm TCE
                          so, the PCM is the alternator's regulator? that is so VERY odd...
                          • Weatheralls Auto
                            • Dec 2009
                            • 536
                            #88
                            EGR Command from 0 to 100% by 10s then back down to 0% then return control to PCM
                            AE 01 00 00 00 00 40 1A
                            AE 01 00 00 00 00 40 33
                            AE 01 00 00 00 00 40 4D
                            AE 01 00 00 00 00 40 66
                            AE 01 00 00 00 00 40 80
                            AE 01 00 00 00 00 40 99
                            AE 01 00 00 00 00 40 B3
                            AE 01 00 00 00 00 40 CC
                            AE 01 00 00 00 00 40 E6
                            AE 01 00 00 00 00 40 FF
                            AE 01 00 00 00 00 40 00
                            As of April 2
                            Injectors: #36 GTPs
                            TB: 65mm TCE
                            • Weatheralls Auto
                              • Dec 2009
                              • 536
                              #89
                              The PCM can reduce the amount the Alt produces to reduce load when not needed.
                              As of April 2
                              Injectors: #36 GTPs
                              TB: 65mm TCE
                              • Weatheralls Auto
                                • Dec 2009
                                • 536
                                #90
                                Ahhhh, Need to test if this works across more platforms
                                CKP Variation ReLern
                                AE 01 00 00 02 02 00 00
                                Then hit throttle to WOT until fuel cutoff!!!!
                                As of April 2
                                Injectors: #36 GTPs
                                TB: 65mm TCE
