Question for the Gurus
  • Weatheralls Auto
    Spinning out of control
    • Dec 2009
    • 536
    While I wait for my 4X Speed cable, I know I will need to have a bootloader to be able to Download/Upload bin files to the PCM.
    (I believe most GM OBD2 Pcms use Motorola 68332 chip? )
    I really don't know assembly at all, but may have someone to help me (he codes low level language for AMD and now for HD TV tuners)
    First step I have read is removing the chip and installing in a reader to dump the info.
    Here is where my question lies;
    All the OBD2 flash files I find are 512Kb, is that the WHOLE chip? If I give that file to this guy to work with, will it be possible to write the bootloader? or is there more info that absolutely needs to have the chip removed and dumped?
    As of April 2
    Engine: 2006 SV6 3500 LX9
    Trans: 2002 Getrag F23 5speed
    Injectors: #36 GTPs
    TB: 65mm TCE
    Maf: 1999 3400 Montana.
    Beverages: Ice Cold CANADIAN.
    if the OBD2 PCMs are like the OBD1.5, then there are actually 2 flash chips inside the PCM. regardless, if you're going to actually remove the chip(s) from the PCB and install into an EEPROM reader/burner, you wouldn't need any type of bootloader.
    • Weatheralls Auto
      • Dec 2009
      • 536
      My goal is to do this without removing chip, trying to get as much info on the chip to help in dumping it.
      As of April 2
      Injectors: #36 GTPs
      TB: 65mm TCE
        it may be called something different, but on the 94-95 LT1, you use mode 3 commands and then the PCM spits out the entire BIN... i imagine given the correct command, the OBD2 PCMs should do the same. i've been trying to find something like hyperterminal to do it with the 93-95 3100, but can't find anything that wants to work with vista...
        • Weatheralls Auto
          • Dec 2009
          • 536
          The Pcms do not have a routine built in to dump file unfortunately, so now I need to learn asm to write bootloader lol.
          As of April 2
          Injectors: #36 GTPs
          TB: 65mm TCE
            really? OBD2 FTMFL!
            • 91LQ1Lumina
              Humm, Quad Cam Goodness!!
              • Feb 2008
              • 136
              I am sure you have already checked this out, but if not here you go. I have used this version of Hyper terminal on Vista before, and it's free to download for personal use.
                http://www.brothersoft.com/hyperterm...ion-71955.html
                that seems familiar for some reason...
                thanks for the link, i'll see what i can make of it.
                • Weatheralls Auto
                  • Dec 2009
                  • 536
                  Well I took apart 1 Pcm I had here, The Flash chip said
                  INTEL
                  16236995
                  AB28f400BX
                  U8390438Q
                  So I assume it is an Intel 28F400BX based Flash Chip?
                  When I read that it is "motorola 68330 32bit code" that means that Chip is coded with a Code Style named motorola 68330 32bit ?
                  Sorry, a newb when it comes to this but am learning.
                  As of April 2
                  Injectors: #36 GTPs
                  TB: 65mm TCE
                    both things sound right. the OBD1.5 PCM i have torn apart at the moment has these things printed on it:
                    Intel
                    16155187
                    AN28F256A
                    E 5012AC
                    U4030107
                    IDAPro supports the 68330...
                    • Weatheralls Auto
                      • Dec 2009
                      • 536
                      I have seen IDA mentioned a few places I have been searching, I guess it is a Program I should get?
                      ( I posted elsewhere that I had opened with Hex Workshop and even Olly Debugger lol, but Hex not showing me to much)
                      As of April 2
                      Injectors: #36 GTPs
                      TB: 65mm TCE
                        i'm still working on learning it myself, but it is highly recommended.
                        not cheap IIRC.... but the internet is VERY full of resourceful people...
                        • Weatheralls Auto
                          • Dec 2009
                          • 536
                          How old is version
                          The IDA PRO Disassembler and Debugger version 5.2
                          I seen mention of that version of over 2 years ago, not sure how up to date it is?
                          As of April 2
                          Injectors: #36 GTPs
                          TB: 65mm TCE
                            mine is 5.5.0.925t
                            • Weatheralls Auto
                              • Dec 2009
                              • 536
                              I will keep searching then, thank you.
                              (does it have a build date? so I get a reference of when newer once were released? )
                              As of April 2
                              Injectors: #36 GTPs
                              TB: 65mm TCE
