? about HPT
  • Weatheralls Auto
    Spinning out of control
    • Dec 2009
    • 536
    ? about HPT
    Do you need a Vin Licence to view a file and export tables? (not reading or writing)
    example - > http://www.mediafire.com/download.php?mmw4omunozk
    This is a file from a 98 Pontiac Sunfire 2.4L 5 Speed.
    I am trying to get as many (all available if possible) Tables in xls etc.
    The Vin of the file I have linked in post is
    3G2JD12T3WS822691 and Osid should be 16754010
    I can change Vin to what ever if need be, but dont know if its necessary?.
    As of April 2
    Engine: 2006 SV6 3500 LX9
    Trans: 2002 Getrag F23 5speed
    Injectors: #36 GTPs
    TB: 65mm TCE
    Maf: 1999 3400 Montana.
    Beverages: Ice Cold CANADIAN.
  • Weatheralls Auto
    • Dec 2009
    • 536
    It might have been a corrupted file or filename
    here is another copy, if this doesnt work I will need to find another file.
    As of April 2
    Injectors: #36 GTPs
    TB: 65mm TCE
      • 13534
      failed validation check. I haven't exported a table in hptuners so I am not sure on that right now.
      • Weatheralls Auto
        • Dec 2009
        • 536
        Thanx for having a look.
        Your not the only one who has that error.
        Not sure if file is corrupt or encrypted.
        I am digging deeper to see if it can be repaired or if I can get a good copy.
        As of April 2
        Injectors: #36 GTPs
        TB: 65mm TCE
        • AJxtcman
          • 5
          When I get home tonight I will get you a HPT file.
          I need to teach you how to convert an HPT to a bin
            • 13534
            Id love to know how to do that.
            • AJxtcman
              • 5
              I know of a person converting them for $100
              So I have spent the last day crapping myself over how much HP Tuners has left out. It kind of sickens me to know that I spent that much money with them and they missed so many tables. Anyways. I've never had my eyes on any open loop tables before, so I am not exactly sure what table does what...
                • 13534
                Have to be registered to read that thread and im not paying 100 bucks to convert hpt to bin. Sounds like someone writes the pcm with HPT and reads it with DHP.
                • AJxtcman
                  • 5
                  Originally Posted by LNorton
                  I really wish I had a way to convert .hpt files to .bin files myself.
                  Originally posted by Caleditor
                  Straight conversions have to be worth $100
                  The VCM ID would match up if you used a different PCM
                  • AJxtcman
                    • 5
                    It didn't take me long to ID over 20 tables.
                    • Weatheralls Auto
                      • Dec 2009
                      • 536
                      I have been able to figure out how to convert some .hpt to bins, like the V6's but not the 4 Cyl yet, as Hpt seems to split them up.
                      Send me one of your Modified V6 .hpt files and I will give it a go.
                      As of April 2
                      Injectors: #36 GTPs
                      TB: 65mm TCE
                        i wonder if it's as easy as the tunercat .cal files.... those just had an extra 1K of space at the beginning of the file
                        • Weatheralls Auto
                          • Dec 2009
                          • 536
                          No, as the HPT files are actually smaller then the raw Bin files.
                          Its a case of basically dumping memory and locating file and cutting it out.
                          As of April 2
                          Injectors: #36 GTPs
                          TB: 65mm TCE
                          • AJxtcman
                            • 5
                            So you were able to figure it out. Hmmmmm You are doing better than myself.
                              • 13534
                              I only want the ability to help those with a DHP tune their car. I don't have anything modified that I want converted for any particular reason.
