How to flash a *.bin file to PCM?
  • Schmieder
    • Dec 2009
    • 766
    I use HPTuners but I need to flash a bin file to my pcm.
    I don't need any scanning abilities, hence HPTSuite. I just need to flash this bin to my PCM. The issue is certain tables I NEED edited which HPT doesn't offer. Solution is to alter the files I need to and flash the bin then use HPT to further fine tune fueling.
    Everytime I load the bin into HPT it gives me an OS/VIN match error. This is because the 97 bins do not contain a vin#. But I can not flash a vin to the bin w/ hpt.
    If anyone knows the CHEAPEST method to simply flash a bin file, please clue me in.
    OR, if someone can take my bin file and convert it to HPT WITH my VIN, that will also be just as great.
    I attached my BIN. It is a 1997 Chevrolet Lumina PCM in a 96 GP.
    VIN# 2G1WL52M8V1167046
    VCM ID: 8N6W057038
    VCM OS ID: 16245158
  • skeeter1
    • Nov 2010
    • 9
    HP Tuner can flash a bin file, you need the correct vin info put in the bin file and then you should be good to go.
    • Schmieder
      • Dec 2009
      • 766
      It was a bit more complicated then that but all is well now. I had to insert the VIN via hexadecimal editor into the bin code. TT wouldn't put the VIN in a 97 PCM and HPT is a ***.hpt file. But HPT wouldn't flash the bin w/o a VIN. I needed the bin, not the hpt file, so TT could edit other tables HPT didn't offer.
      It was a catch 22 all the way. After I inserted the VIN I flashed it, tested it and all worked well. Found out it messed up some of the table or code for the supercharger settings. Which weren't used so I lucked out.
      I am considering a MSIII system with EGT's for each cylinder to keep the injectors balanced.
      Thanks anyways
        • 13525
        What tables do you need HPTuner to add?
        • Schmieder
          • Dec 2009
          • 766
          They were Map Sensor Offset and Map Scaling Factor, most importantly. For 2 bar Map. I have already included this request in the specific thread regarding and also on HPT forum.
          But being the perfectionist I try to be, in theory, I need access to every table. Unless HPT will do that, doubtful, I'll have to stick with VIN hacking or go MSIII.
          I gotta say, MSIII is looking like the better option day by day. Especially if I build an EGT system with 7 sensors.
