Anyone in MD?
  • hookdonspeed
    • Jun 2007
    • 322
    Anyone in MD?
    anyone in MD know anything about tuning? about to start tuning on my 3500 swap into my fiero... have DHP tuner.
  • neophile_17
    • Jun 2004
    • 306
    I'd love to see that setup and how things go. Maybe I'll go to OBD2 next time.
    ~sam
    actually Cockeysville, MD (I should update that...)
    • hookdonspeed
      • Jun 2007
      • 322
      as soon as i get it running id gladly let ya take a look :P
      im over in essex (the wooded part not the ghetto part )
      • neophile_17
        • Jun 2004
        • 306
        Nice,
        I love the idea of the 3500 but decided to go for the 3400 to keep the downtime low. Hope you get it tuned soon.
        ~sam
        • hookdonspeed
          • Jun 2007
          • 322
          i cant even get the damn thing to start :/ im really pulling my hair out!
          • neophile_17
            • Jun 2004
            • 306
            Do you know for sure what's holding you back, air, fuel, or fire?
            • hookdonspeed
              • Jun 2007
              • 322
              fuel, i cant get the f'ing injectors to fire... (checked with noid light) was running98 venture pcm, thought "maybe bad pcm" grabed an 01 impala, same issue...
              goiing to re-scope out all the sensor readings tonight, and try the 98 ecm again :/
              • neophile_17
                • Jun 2004
                • 306
                I don't know if it's the same for OBD2, but OBD1 needs extra grounds from the block to ECM to fire the injectors. Did you test to see if you have power at the injector plug with the ignition on? You could also try triggering them manually. Would get you enough fuel in the manifold to see if the rest of it's working. Good luck.
                ~sam
                • unchained01
                  • Jan 2011
                  • 388
                  X2 on the grounds and do you have the right crank sensor ?
                  • hookdonspeed
                    • Jun 2007
                    • 322
                    was bad pcm... flashed a yard pcm w/ the non-vatts 98 programing, got injecors and all, taped it with a hit of starting fluid... it started for all of 10seconds before it went CLUNK
                    and locked up
                    • unchained01
                      • Jan 2011
                      • 388
                      sorry to hear that
                      • hookdonspeed
                        • Jun 2007
                        • 322
                        not as much as me!!
                        ima drop the pan/ pull the plugs/vc /heads etc and see if i cant figure out what
                        happened...
                        • neophile_17
                          • Jun 2004
                          • 306
                          Sounds like it's time for a trip to Crazy Rays. There were 2 3500s at the Edgewood yard last weekend. My condolences.
                          ~sam
                          • hookdonspeed
                            • Jun 2007
                            • 322
                            ohh, nice, thats good to know, the one on erdman ave didnt have any sat when i went (was just looking for misc nuts and bolts) well hopefully i wont need that? :/ but probably will lol...
                            • neophile_17
                              • Jun 2004
                              • 306
                              Prognosis?
