Master pinout/16236757
  • ericjon262
    build it.
    • Jan 2010
    • 2218
    I've been working on a master pinout for the 16236757 and similar obd2 60V6 PCMs thought I would share my progress, anything labled "O" I don't have info on. I've attached the sheet as a PDF.
    some interesting notes:
    • there are 3 O2 sensor inputs on this PCM, one for each bank, and one for post cat
    • some 3800's use the same PCM's, and have dual knock sensors.
    I've made a table of the different vehicle pinouts, that show's which vehicle used which pin, it can be viewed here:
    I tried posting it here, but this site didn't like the table, it just made a big ugly list...
    here's the list style:
    Blue PCM connector pins
    1. Transmissino fluid temp Sensor ground
    2. 2nd gear start indicator
    3. Fuel level output
    4. Shift solenoid a
    5. Fan 2
    6. Fan1
    7. Cam position sensor input
    8. Low frequency crank position
    9. High frequency crank position
    10. 5 volt reference
    11. O
    12. ECT ground
    13. Map ground
    14. O
    15. Serial data
    16. PCM ground
    17. IAT Ground
    18. O
    19. Ignition Feed
    20. Battery Feed
    21. O
    22. Transmission range A
    23. O
    24. O
    25. O
    26. O
    27. HO2S
    28. HO2s
    29. HO2S
    30. TCC brake input
    31. EGR pintle position sensor ground
    32. EGR control(EGR Ground?)
    33. Bank one knock sensor
    34. Bank two knock sensor
    35. O
    36. Alternator charge warning lamp(generator control?)
    37. O
    38. IAC B High
    39. Fuel pump speed control relay
    40. O
    41. O
    42. O
    43. Injector control (1 60v6/6 for 3800)
    44. Shift solenoid B
    45. AIR valve control
    46. Injector control (3 60v6/4 3800
    47. Injector control (2 60v6/5 3800
    48. Reference low (IGN mod ground)
    49. O
    50. O
    51. O
    52. O
    53. Ignition control bypass
    54. Ignition control
    55. VSS output
    56. PCM ground
    57. PCM ground
    58. ClassII (? typo maybe, 2000 grand am 3.4 pinout)
    59. Class 2 serial data
    60. PCM ground
    61. TPS ground
    62. Input shaft speed sensor low (4t65e)
    63. Input shaft speed sensor high(4t65e)
    64. VSS high in
    65. VSS low in
    66. O
    67. O
    68. Transaxle range position switch B
    69. MAF Signal
    70. Theft deter fuel enable
    71. Traction control desired torque input
    72. Cruise control inhibit
    73. Injector control (5 60v6/2 3800)
    74. O
    75. ECT hot warning lamp
    76. EVAP purge solenoid
    77. O
    78. O
    79. Injector control(6 60v6/1 3800
    80. A/C pressure sensor ground.
    Clear connector
    1. O
    2. EVAP canister vent control
    3. Fuel pump relay control
    4. EGR Valve control
    5. SES light
    6. Low oil light
    7. IAC valve A High
    8. Tach output signal
    9. Traction control delivered torque control
    10. HO2S signal
    11. HO2S signal
    12. HO2S signal
    13. O
    14. O
    15. Transaxle range switch P
    16. PNP switch signal?
    17. Transmission range C(4L60e)
    18. Transaxle range switch A (clutch anticipate switch)
    19. Oil pressure switch
    20. O
    21. 2nd gear start signal
    22. A/C request
    23. Crank signal?
    24. Ignition positive voltage
    25. Map sensor signal
    26. ECT signal
    27. A/C pressure signal
    28. EGR pintle position signal
    29. generator pin F
    30. 5 Volt reference
    31. O
    32. Fuel tank pressure 5 V ref A
    33. 5 volt reference A
    34. 5 volt reference B
    35. Fuel tank pressure/level Sensor ground
    36. Change oil lamp
    37. O
    38. O
    39. A/C compressor relay control
    40. O
    41. O
    42. Injector control(4 60v6/3 3800)
    43. O
    44. IAC valve A Low
    45. Pressure control solenoid high
    46. Pressure control solenoid low
    47. O
    48. 3-2 solenoid control
    49. IAC valve B Low
    50. IAT sensor
    51. O
    52. O
    53. O
    54. O
    55. Fuel tank pressure signal
    56. Transaxle range switch C
    57. Transmission range B (4L60e)
    58. Oil level signal
    59. Cruise status
    60. O
    61. Generator terminal L
    62. O
    63. TCC release switch input (4t65E)
    64. O
    65. O
    66. TPS signal
    67. O
    68. Trans fluid temp signal
    69. Fuel level sensor input
    70. High frequency crank position ground
    71.
    72. Cam position power supply
    73. Cam position sensor ground
    74. High frequency crank position power supply
    75. AIR pump relay control
    76. Starter enable (VATS?)
    77. Boost control solenoid control circuit
    78. TCC PWM solenoid control
    79. TCC enable solenoid control
    80. O
    so that's what you were working on...
    • ericjon262
      build it.
      • Jan 2010
      • 2218
      yeah, thought it might be useful for 5 speed swaps, I plan to wire up the clutch switch like the 5 speed 3800 F bodies. it's also interesting to see some of the other inputs that aren't in use on our engines. it would be interesting to see some of them "patched" to our programming, like the dual knock sensors, and left and right O2 sensors.
        i can't read 68332 disassembly very well, otherwise i might have had a little info on that...
        the dual O2 sensors MAY be able to be done due to SAE requirements of O2 sensor data being loggable. the PCM likely wouldn't be able to make fueling adjustments off of it, but you would be able to log it.
        the dual knock sensors... i know a little about how that setup works since i've investigated it a bit myself for OBD1 retrofit. there is a small chip inside the PCM that directly interfaces to the knock sensors, there's actually programmable settings for target frequency, sensitivity, etc... anyways, the main processor sends info over the SPI link to the knock sensor chip and it will constantly grab data from the selected knock sensor(s) and report back when it determines knock has been found. selecting between 1 and 2 knock sensors is as simple as sending a slightly different command over the SPI link. if one were to know where the SPI data is written to in the program, you could probably see an option bit selecting between 1 and 2 sensors...
        • ericjon262
          build it.
          • Jan 2010
          • 2218
          I don't know much on the programming side, I'm going to learn more on that down the road
          • TGP37
            Shadetree Engineer
            • Jul 2011
            • 1027
            After I finally learned how to really disassemble that code, I then realized HOW much work that will take. I respectfully gave up that project knowing it would be years of study.
            Even with basic programming knowledge it was a massive headache.
            I'll see what I can come up with Eric.
            • ericjon262
              build it.
              • Jan 2010
              • 2218
              I have a 3800 5 speed bin now, it looks as though both bin files have the same trouble codes available, but the trouble codes turned on are not the same, could adding bank to bank o2's be as simple as turning on a trouble code?
              edit: actually, there are a few trouble code missing here and there, but all of the o2 sensor codes are there in the 60V6 bin.
              edit again:
              P0243 Turbocharger Wastegate Solenoid A Malfunction
              hmmmm
              edit(a third time):
              it's also interesting to see codes like p307 and p308... misfire detected cyl 7&8...
              edit(lol):
              I see the knock sensor codes in there too...
              should I keep listing edit??
              oh well
              Edit:
              in tiny tuner:
              Configuration>Main>o2 sensor config for PID 13
              change value to 21 to match 3800 f body with dual o2's?
              Edit(oh shit... now I'm editing my edits...) 1998 GTP bin uses "3" like our 60V6, I know PID 13 defines o2 sensor reading, but I don't see specifics... I would be willing to bet changing that value would enable bank 2 o2 sensors.
              if you have any info on PID 13, it would be helpful, there's not a whole lot of info through a google search, and the tuning forums I've been on have no mention of it.
              • TGP37
                Shadetree Engineer
                • Jul 2011
                • 1027
                Here is what I know so far......
                Using HPT Beta, the 97v6 controller w/ OSID 9355440
                In the Open & Closed Loop tab, there is an option for 1 or 2 bank o2 sensor config. But only available in the Beta version. I don't know where that would be in Tiny Tuners. The option above, Exhaust Config, is straight or dual out. I suppose that controls how many downstream O2's are used. As 1 bank straight or y is 1 rear o2. But 2 sensors upfront can have 1 or 2 rear o2's if there are twin or single catalytics used.
                I also noticed there are 3 sensors among 2 banks in the DTC list.
                bank 1 sensor 1
                bank 1 sensor 2
                bank 1 sensor 3
                bank 2 sensor 1
                bank 2 sensor 2
                bank 2 sensor 3
                What could possibly be the 3rd sensor? Could that be a wideband capable input? Dual O2 per bank?
                I can understand 2 sensors per bank with 2 banks. So I hope I helped but I think I probably introduced more questions then I tried to help answer, lol.
                EDIT: Possibly look up people throwing DTC p0151 (or other bank2s1 codes) to find which GM vehicles have dual front o2's. Then find out which ones use the same type of PCM. Then it is just a matter of getting the wire diagrams and pin outs for that particular vehicle.
                I am finding Chevy Silverado 2002 with the 5.3l as throwing p0151. It might be a big block thing. It might be a truck thing, I really don't know atm. But I am interested as well, i also want twin o2's and hopefully have twin catalytics down the road.
                • caffeine
                  • Jan 2012
                  • 1489
                  Is it ok to have O2 sensors pre-turbo? I always thought for some reason they should be post-turbo, in which case you would only need one narrowband anyway.
                  '86 Fiero, 3500, 4-speed
                  • ericjon262
                    build it.
                    • Jan 2010
                    • 2218
                    I don't think it is ok to run pre turbo o2's, I was just sharing my insights. on a twin turbo car though you could use dual o2's.
                    @ TGP37 I think is has less to do with the DTC's and more to do with the PID.
                    • TGP37
                      Shadetree Engineer
                      • Jul 2011
                      • 1027
                      You can use NBO2 pre-turbo, they just fail sooner as far as I can tell. Though I did use a pre-turbo NBO2 for 3 months, spirited driving of course. I didn't notice any major changes in operation. But then, it was only 3 months of driving. I changed manifold details.
                      Yeah Eric, though with DTC's, if a NBO2 sensor is turned off it can't report to any inquiring device (for inspection and I suspect the PCM Bus). But turning no reporting keeps it operational but not responsive. I wonder how much the DTC list has command over functionality of such systems.
                      IIRC, a PID is a variable, not a hardware thing.
                      Gotta run but I want to continue this topic later.
                      • ericjon262
                        build it.
                        • Jan 2010
                        • 2218
                        you can edit the PID in tiny tuner, I was just meaning that I don't think turning the code on will make bank to bank active, I think you can only activate it by changing the PID settings.
                        • TGP37
                          Shadetree Engineer
                          • Jul 2011
                          • 1027
                          Ahh, I see what you meant.
                          Seriously though, look up what GM vehicles toss any DTC code for the 2nd O2 sensor. P0151, P0152, P0153, P0154, P0155. Weed out the ones that might apply and then we can dig up some pin outs. Maybe apply 0.7v to the suspected pinout and see if DHP or HPT can pick up on the signal for the B1S2 O2.
                          If you have a spare PCM, you could apply 0-1v to each blank pin while logging the vehicle (not running though, key on) and see which one triggers the S1B2 O2 data signal to jump. If none trigger it then it must be activated. This test would rule out the need to activate it or not in order to log it.
                          I've been quietly looking into this as well for the last few days. If and when I do find something, I'll definitely pass it on.
                          EDIT: I learned once the PCM looks for a ground in the heater circuit for the presence of an O2 sensor, determines if closed loop is possible. I suppose it may be logical to assume a second bank O2 may operate the same way. If the PCM detects a ground in the heater circuit (meaning it is plugged in).
                          Or however the PCM determines if there is an O2 present, the same should apply to the second. Then it should be just a matter of wiring it up and letting the PCM determine. Because activating open loop and closed loop will turn on the 2nd bank O2 with the 1st bank....or just the 1st bank on single systems.
                          • ericjon262
                            build it.
                            • Jan 2010
                            • 2218
                            we already know which pins they are based on the 3800 pinouts, I went ahead and posted the pinout directly to the thread, that leaves it all up to the programming side of things.
                            • TGP37
                              Shadetree Engineer
                              • Jul 2011
                              • 1027
                              Ahh nice, did you try allowing the PCM to go closed loop with the second O2 wired up? It may be plug n play IF the 1st O2 is configured to turn on. Because I can't find a temp setting for closed loop bank 2. Which I gather the 2nd O2 is activated when the primary upstream is. To some degree a lot of the settings for the primary upstream I assume is shared with the 2nd primary.
                              However, noting the file I have has a setting to activate the 2nd O2......and a setting to determine how many downstream O2's.
                              If HPT allowed me to save in Bin format then I could easily pin point the setting in a binary editor.
                              Edit: I do believe there are still tables Tiny Tuner doesn't list, but not many. TT is open ended so you can learn to insert new tables you discover in a binary editor of some kind.
