How to kill VATS dead
    • 13522
    Finally got our PCMs to work and figured I would share it with anyone else that might run across this issue. Car won't start/crank, or the car starts and then dies.
    Setting the VATS to PWM rather than Serial will get the car to run. Turning off Codes 1626-1631 will let it stay running.
    So far so good with this setup.
    neat. the 93-95 60V6 SFI code actually works really similarly.
      Ben did you search for this on HPTuners? I found a thread from 07 talking about it... It doesn't have the same codes listed as you do, but similar procedure.
      http://www.hptuners.com/forum/showth...&highlight=pwm
      I've also done this on my moms old 2000 Grand AM when it continued to screw up on her, except the procedure was slightly different in DHP. And I think that was passkey, but I'm not sure. Similar, you set the system to "disabled" then have to shut off codes otherwise it will only let the car run for a second, or just crank.
      • geldartb
        The Situation
        • May 2004
        • 1994
        is it just the codes listed in that link. what other part did you turn off.
        99 Grand Am GT
        1357 cam 227 233 .050 dur
        515 515 lift 112 lsa
        • Guest
          What PCMs? There are literally dozens of different PCMs used by people on this board.
            • 13522
            Obd 2
            • Guest
              Obd 2
              Yeah....
              A little more specific would be nice...
              Service number...?
              BCC...?
              (Known) Applications...?
                • 13522
                60V6 OBD2
                • ericjon262
                  build it.
                  • Jan 2010
                  • 2218
                  there are different service numbers, but the functionality and programming is pretty much the same between them from what I've seen.
                  • onefastV6
                    • Sep 2005
                    • 880
                    If you have a DHP PowrTuner, you would do the following to disable VATS:
                    1. Under The Security Tab - Vehicle Theft Deterrent: Select "VTD_Present_On_Car and set to "False"
                    2. Under Diagnostics - Fault Reporting - DTC Fault Type: Set Codes 1626-1631 to "No Reporting"
                    2000 Grand Am GT
                    2011 Chevy Impala
                    • ericjon262
                      build it.
                      • Jan 2010
                      • 2218
                      when you set to disable, do you input a "1" or a "0" in the VTD present on vehicle box? I'm assuming a "0", but I want to make sure....
                        via boolean logic, a 0 for "VTD present" would mean it's not present.
                        • ericjon262
                          build it.
                          • Jan 2010
                          • 2218
                          that's what I thought, thanks.
