expanding tuning capabilities?
  • ericjon262
    build it.
    • Jan 2010
    • 2218
    how do we go about revealing more of the tuneable tables in a bin file? I don't have anything specific that I'm looking for, but it would be neat to see what else is in there, and what else we might be able to do with it.
  • roughneck427
    • Feb 2010
    • 16
    Post up a .bin file that your wanting to see extra
    • ericjon262
      build it.
      • Jan 2010
      • 2218
      I attached the file my tune is based on.
      • ericjon262
        build it.
        • Jan 2010
        • 2218
        I have the database open in tiny tuner, so I can see alot. but I know there are things left out. just like on the the 04 Grand prix GT bin I was looking at the other day.
          if you want to really get into it, you're going to have to disassemble a target BIN in something like IDA and go from there. and it's a LONG process from there.
          • ericjon262
            build it.
            • Jan 2010
            • 2218
            what kind of software would I need?
            • caffeine
              • Jan 2012
              • 1489
              Are you an assembly programmer? I've done a bit of x86 assembly here and there but I can't imagine the amount of hours required to make sense of an ECM binary disassembly .
              '86 Fiero, 3500, 4-speed
              • ericjon262
                build it.
                • Jan 2010
                • 2218
                no, I'm not, I just like learning how to do new things. tuning/programming and suspension design are both on my list of things to learn.
                • caffeine
                  • Jan 2012
                  • 1489
                  I'm all for you expanding on obdII tuning but it would probably take an extensive amount of time .
                  • ericjon262
                    build it.
                    • Jan 2010
                    • 2218
                    time is one thing I don't have this instant, but I should have a little more to work with soon.
                    edit:
                    I've made what I think is good progress on the 5 speed conversion info. things like the clutch anticipate input should help alot, along with the proper programming.
                    • caffeine
                      • Jan 2012
                      • 1489
                      If you're unfamiliar with assembly programming, its basically machine code expanded into something that can be read.
                      Generally one command per line of code, very basic.
                      I've never looked at an ECM binary disassembly but I imagine to make sense of it you would have to start from the very beginning of the code and trace every command, taking notes, to figure it all out. If you had an idea of where the tuning scalars and tables were located that would help immensely, but it would still take forever.
                        You will want to put your head in a vice if you attempt to figure out a bin file and have no programming background... LOL I'm an IT Admin, but I specialize in hardware networking and base software setups... I do not dabble in programming so I don't even try to figure out tables in bin files.
                        Eddie is the one who wrote TinyTuners and he spent a lot of time digging to find what he did... Unfortunately I don't think he is digging any further, but really what we need is a few guys who don't mind doing this and try to get an open source group going. Subaru has a huge open source tuning following and they have some guys who tear apart these files so I don't see why we couldn't do the same but obviously it would require a lot of time invested by those who truly understand this stuff. And I don't think it would be right for them to not be compensated in some way for it either, but with the donations that I see the website not getting I fear that we don't have the support to motivate those people. The Subaru group has also written an entire program to scan and tune with on top of opening up these files...
                          i got bored and decided to do a quick(and probably incomplete) disassembly....
                          good luck. maybe you'll see something i don't, but i hate trying to keep up with the CPU32 core, has WAY too many registers to keep track of.
                          • ericjon262
                            build it.
                            • Jan 2010
                            • 2218
                            http://wikisend.com/download/128858/...a_09369232.asm
                            Thanks! looks like it's time for me to learn a new language...
                            I'll see what I can do. but after looking at the file robertisaar posted, it'll be a while before I have any real data to give... it is less cryptic then I expected though.
                              not only a new language, a new way of thinking. since you have the database for tinytuner open, maybe you can start matching tables up and see some of the patterns that are bound to come up between similar tables.
