expanding tuning capabilities?
  • ericjon262
    build it.
    • Jan 2010
    • 2218
    I've got several friends that know programming fairly well, maybe I can enlist a little help...
      68000 Editor Assembler Simulator for Windows
      that may be of some use, especially if you start adding stuff into the program, like expanded MAF tables(i know the LS1 guys get this from EFI-Live) or other things you might want to impliment.
      • ericjon262
        build it.
        • Jan 2010
        • 2218
        http://www.easy68k.com/
        well, I'm definitely looking into expanding the MAP tables to 3 bar, and probably the MAF tables too. a side project I would be even more interested in, would be true coil per cylinder ignition.
        • roughneck427
          • Feb 2010
          • 16
          Heres all the parameters i can change in Tunercats
          • ericjon262
            build it.
            • Jan 2010
            • 2218
            I see some very interesting notes in there...
            SWITCHES:
            Calibration Options
            0 2 Speed Fuel Pump
            0 AIR Pump Option (X = Present)
            0 Disable Accel Enrich in P.E.
            0 Flash Checksum Option (X = Disabled)
            X IAT Sensor Option (X = Present)
            X Shift Quality Controlled by PCM
            0 Supercharger Option (X = Present)
            X Abuse Torque Reduction (X = Enabled)
            X Shift Energy Management (X = Enabled)
            0 Dual Bank Fuel Control (X = Enabled)
            0 Serial Com. Fan Control
            Auxiliary Output Diagnostics
            0 1-4 Upshift Lamp Control Circuit (P1664) No Error Reporting (Type X)
            I wanted to add this to my Fiero, just to add to the stock feel a little bit, I didn't think it was possible with this PCM... ***this may be available through DHP or Tiny Tuner, I didn't look very hard.***
            Edit, opened up DHP, and you can add this through DHP.
            • ericjon262
              build it.
              • Jan 2010
              • 2218
              #21
              are you using the obd2 tuner that is now branded as a "JET Dynamic Spectrum Tuner"
              Edit: nope, it doesn't support that PCM. or at least, through jet it doesn't...
              • ericjon262
                build it.
                • Jan 2010
                • 2218
                #22
                ok, after looking at the the bin again, I've determined that the main thing I need to do is expand the fuel, spark, and MAP tables, I'd like to take the MAP to 3 bar, and fuel and spark to 8500 RPMs, right now, they level off at 6400.
                • roughneck427
                  • Feb 2010
                  • 16
                  #23
                  No ive had Tunercats for abt 8 years i got it before it was licensed to Jet
                  • ericjon262
                    build it.
                    • Jan 2010
                    • 2218
                    #24
                    FYI, it can be downloaded through Jet's website for free.
                    • roughneck427
                      • Feb 2010
                      • 16
                      #25
                      Yeah without the interface its just a demo deal Jet charges $100 to license each ecm when you tune it too. Tunercat no license lockdown
                      • ericjon262
                        build it.
                        • Jan 2010
                        • 2218
                        #26
                        I haven't had any trouble using the software, just made a quick change to a bin file with it, saved no problem. I don't need it for upload, I have a DHP unit for that.
                        the reason I mention it, is that there are at least a few tables in there, that aren't in DHP, and Tiny tuner.
                        • roughneck427
                          • Feb 2010
                          • 16
                          #27
                          Well Jet is a .JCL file which is encrypted changing it to a .bin may have ill results open both files in a hex editor and you will see. Post up if you able to flash it or not
                          • ericjon262
                            build it.
                            • Jan 2010
                            • 2218
                            #28
                            I haven't converted anything, I loaded the bin into the program, just as I have with tiny tuner and DHP
                            I'll keep you guys posted on it.
                            • ericjon262
                              build it.
                              • Jan 2010
                              • 2218
                              #29
                              DOH. I see what you meant now, it won't let you save the file to a .bin, only to a .jcl...
                              this sucks. I was looking forward to playing around with that.
                              • ericjon262
                                build it.
                                • Jan 2010
                                • 2218
                                #30
                                please bear with me, I'm a bit new to tuning and programming, but after looking at the descriptions on TunerCats website, I should be able to expand the fuel/ignition/map/maf tables using their VDF editor. is that correct? if that's the case, that should save quite a bit of leg work.
