obd2 LQ1
  • ericjon262
    build it.
    • Jan 2010
    • 2218
    obd2 LQ1
    does the obd2 LQ1 use the same 40x sensor under the balancer and cam sensor/reluctor as the 31/3400's?
  • caffeine
    • Jan 2012
    • 1489
    The 3100/3400s use a 24x secondary crank trigger.
    '86 Fiero, 3500, 4-speed
      • 13525
      Yup, sensor on front intake cam and the crank pulley.
      • ericjon262
        build it.
        • Jan 2010
        • 2218
        so in theory, a LQ1 could be run off of a LA1 PCM?
          • 13525
          I believe so. I have OBD2 LQ1 and have been thinking LA1 swap with the same computer to start with. Its a 92 GP with OBD2 conversion.
          • ericjon262
            build it.
            • Jan 2010
            • 2218
            Thanks, does the cam sensor get it's pickup off of the cam, or the cam cog?
              hmm...... i would expect 0 issues swapping between a LQ1 and gen3(or even the RWD3.4) in terms of cam/crank signals with one possible thing to investigate: cylinder sequencing. all of the OHV engines likely generate a cam pulse for the same cylinder, but i don't know if the LQ1 has the pole in the right spot for that to happen at the same time too, especially if cam timing were being played with.
              • ericjon262
                build it.
                • Jan 2010
                • 2218
                both engines have the same firing order, and I assume, that the cam reluctor is TDC cylinder 1.
                  actually..... i want to say it is cylinder 3 or 5, but it's been a long time since i investigated it. i suppose i could look at the 1FA stuff to be certain, that had the early 94-95 LQ1 calibrations(before they moved to 2E) and all of the 94-95 A-body 3100 MAF calibrations.
