1997 L82 HP Tuners tune file needed
  • LeftVentricle
    Right aorta
    • Oct 2005
    • 506
    In the quest to get my black wagon running again, I want to see if using the '97 W-body PCM from the LX9 wagon will make it run. Toward that end, I need to use a stock L82 tune to start with, and make changes from there, like for tire size and final drive ratio. I am unable to locate an HP Tuners-compatible file myself. There's one for a '98 GP in the tune repository on hptuners.com, but it's mislabeled as being for an L82 (the VIN checks as an L36). Would anyone happen to have an HP Tuners-compatible stock L82 tune I could use as a base? Thanks.
    EDIT: never mind, I'm a clown. As soon as I posted this I got a '98 Century file. Derp.
    • 13510
    Ill upload this anyway, in case it helps.
    • LeftVentricle
      Right aorta
      • Oct 2005
      • 506
      Thanks!
