first time, need help
  • 97malibuLS
    • Feb 2007
    • 10
    what is the easiest way to remove the engine from my car? 1997 malibu LS 3100sfi. have a bad motor and need to replace it.
    • 9190
    Pull it out the top, seperate from the tranny.
    • GPXSS
      • 588
      Depending on how the transmission is mounted in the car when you split it from the engine, you can use a 2x4 across the engine bay front to back and a ratchet strap to hold up the trans while the engine is out.
      I modify stuff
        • 9190
        I always just used an extra jack stand to support the tranny while the engine was out.
        • 97malibuLS
          • Feb 2007
          • 10
          thanks
          thanks guys. i have pulled engines out of older rwd cars but never a fwd i had seen some people pull the whole engine cradle from the bottom and really did not want to do that. so this will save me some time
          • GPXSS
            • 588
            If you have the room and dont need to move the car, that will work to. I always have to wheel the car out while I work on the engine, so the trans has to be supported from above.
            I modify stuff
