Circle Track 3.1L (Modded)
  • communityracingchallenge
    • Apr 2007
    • 30
    First off.. Since this is my first post after lurking for a little while.. I thought I'd do a real quick intro. My name is Patrick, some of you might have responded to a similar thread I had at another GM V6 site, but since this sites seems so much more active, I thought I'd post here also.
    Since what I'm wanting to do is modify a 3.1, I thought I'd put this thread here... I hope this is the right place.
    I race a 3.1L Grand Prix on Friday Nights at Spartan Speedway in Lansing, Mi and on Saturday Nights at Springport Motor Speedway in Springport, MI. Both are oval tracks.. SS is 1/4 mile while SMS is a 3/8 mile.
    Its the the Pure Stock Class at both tracks. This class of racing puts V-8 RWD cars and V-6 FWD cars on the track at the same time and against each other. The rules severely limit the performance modifications you can "legally" make to the cars and good V-6 run very competitively versus the V-8s.
    I'm hoping to find some GM V6 Experts who will help me dial these cars in so we can start running up front. Currently, I'm getting killed by V6 Dodges and V6 Fords (SHO) and all the V8 Chevy's.
    I get in, thru, and out of the corners better then the V8s do, but I'm getting absolutely crushed on the straights.. more then I can make up on the corners... especially as the car first comes out of the corner, there is just no get up and go. Versus the other V6's, they get through the corner as well as I do, and leave me on the straights.
    The track "rules" are posted at the very end of the thread, but I'll tell you know, I don't really care what they say. Racing is full of Pirates, so consider them more like "guidelines" and until I'm running in the Top 3, no one is going to care anyhow. In other words, I'm going all out till somebody makes me start taking stuff off.
    I have gotten a couple of suggestions so far:
    3500 heads w/ exhaust mani, modified 3500 lower intake mani and a slightly ported 3400 intake plenum will look exactly like a stock motor if your given the open hood inspection. that little combo will juice you up for sure
    and some better more detailed advice:
    The 3400 heads on a FWD 3.1 will net the same compression since the FWD pistons have a dish yielding 24cc (if they are aluminum heads). If you go to RWD F-Body/Camero (12cc) the compression will be 11.74:1 (with .060 gaskets).
    I didn't read the rules word for word, but in the engine catagory it didn't say anything about a re-ground cam ,available on non-roller lifters (adjustable rockers) only.
    Circletrack, you didn't specify the year for your engine but I'm guessing you already have aluminum heads?
    Note the 3500 plenum flows far better than the 3400. And the 3400 heads ported will outflow the 3500 heads unless you use custom gaskets since the 3500 aftermarket is close to nill at the moment.
    Make sure the heads you get are 170 or 487 casting numbers, they have larger valves and ports and the LIM to match. They came on some earlier 3400's, and all 3400/3100 after '99 IIRC. Use the TB/plennum from a 3500, the CAMARO pistons.
    The heads you can come by if you watch on ebay, I got a set for $25 (shipping was $40,lol) and was the only bidder. Just look for the casting numbers I gave you.
    I think you will need to get the matching exhaust manifolds to take advantage of the D shaped ports
    At least one person has suggested I just take the 3.1 out and replace it with a 3500. Another suggested a 3400 (not a 3.4 DOHC).
    SO.. Do you guys agree ? Do you have more suggestions ?? What would you do ???
    The mid-season championships are next weekend and July 7th starts the 2nd half, I'd sure like to get off on the right foot for the last 10 races.
    Thanks in advance.
    Patrick
    --- Track GUIDELINES ---
    SECTION 17
    PURE STOCK (FWD) RULES
    A. BODY AND CHASSIS
    B. ENGINES
    C. DRIVE TRAIN COMPONENTS
    D. BRAKES
    E. SAFETY
    Notice # 1: The Pure Stock division is new for the 2006 season. It was added in an attempt to provide a more affordable option to racing. Due to the many makes and models available for use, restrictions and minor changes may need to take place during the season as we learn more about this new division.
    Notice #2: Any interpretations of the rules are left to the officials, whose decisions are final. Just because it is not written, does not mean you can do it. The two words to remember in this class are STOCK ONLY. In the event a car is deemed to have illegal parts the car is subject to being banned from all future race events at Spartan and Springport Motor Speedways. The driver is subject to loss of points to date, all prize money for the night and suspension from property.
    Notice #3: If you are considering building or purchasing a Pure Stock we highly recommend you receive pre-registration approval prior to doing so. There may be cars that have been permanently suspended Spartan because of rule infractions.
    A. BODY AND CHASSIS:
    Any American made FWD V-6 model (no convertibles, 2 seat coupes, super charged or turbo).
    The vehicle must remain in its original form. No alterations are allowed unless specifically stated in these rules. (See notice #3)
    a) Wheel base minimum: 104.5"
    (NOTE: Small-bodied cars not allowed. If you're unsure, call first)
    b) Weights: (post race with driver) 3000 lbs.
    (3800, DOHC, multi-valve add 100 lbs.)
    c) Bumpers must be stock appearing.
    d) Tow hooks are required.
    e) All doors must be welded shut.
    f) Rub rails are allowed (no sharp edges).
    g) Must be able to open trunk and hood without use of special tools. Hood pins required.
    h) Rear and side glass must be removed. Windshield may stay or be replaced with 1/8" thick Lexan. All other glass must be removed including but not limited to taillights, headlights, turn signals, mirrors, plastic, upholstery, carpet, etc.
    i) Any after market add ons must be removed. Ex: trailer hitch
    j) The battery may remain in the original factory location provided it is in a safe location and securely mounted. If the battery is relocated, it may only be relocated to the trunk area. Batteries mounted in trunk must be secured by (2) two 1" metal straps. No batteries mounted in driver's compartment.
    k) Fuel tank to be mounted in trunk and secured with (2) two 1" metal straps (made for racing for fuel cells are recommended). May run plastic gas tank if it is located in front of rear axle, under floor pan and is fully covered with a steel skid plate. Fuel lines must run below floor pan. Tanks that are mounted in the trunk must have protective hoop and 10" of ground clearance.
    l) Front fender inner liners may be removed.
    m) No frame alterations of any kind allowed.
    n) No adjustable shocks or struts of any kind allowed.
    o) Must have stock floor plan to rear axle and all holes in fire walls must be covered with sheetmetal.
    p) Must have battery kill switch mounted on "A" pillar.
    B. ENGINES:
    a) Stock only in stock location. No aftermarket parts.
    b) Single exhaust only. Maximum 2.0" OD. Last 6" of exhaust must exit behind driver and be fully visible. No exhaust leaks allowed.
    C. DRIVE TRAIN COMPONENTS:
    a) Stock automatic only. Cooler are allowed.
    b) Stock diameter working torque converter only.
    c) No aluminum wheels. Steel wheels only, stock for that year, make and model.
    d) 1" Lug nuts are required.
    e) D.O.T. Street radials only. No bias ply, made for racing tires. Maximum width 235. No less than 60 series (no 55, 50, 40). Minimum tread wear rating of 300. All 4 tires and wheels must be the same size.
    D. BRAKES:
    a) Must have 4 wheel hydraulic brakes in working order.
    E. SAFETY:
    a) A four point cage with four driver's side door bars, three right side door bars and a 1/8" steel plate on driver's side door bars from front upright to rear upright and from top door bar to frame rail is mandatory. A front hoop may extend into the engine bay area. Tubing must be .095 gauge, 1.75" O.D. and must be padded around driver.
    b) Made for racing aluminum seat, properly mounted is required.
    c) Quick release five (5) point safety belt with three (3) inch minimum belt width harness securely mounted to roll cage is mandatory. The belts must also contain the original certified date tag and must be less than 3 years old.
    d) Driver's side window net with quick release is required.
    e) A 2 lb. currently dated B or C type dry chemical fire extinguisher is required within driver's reach.
    f) Fuel injected vehicles are required to have fuel pumps wired to stop any fuel from being pumped when engine is not running.
    g) Steering wheel center must be padded. Quick release steering wheel optional.
    h) Refer to section 4 for additional safety requirements.
    • 13531
    What year grand prix?
      • Apr 2007
      • 30
        Live life 3.7mi at a time
        • 4555
        Glad to see you made it over here . And you even quoted me with stuff I learned here
        EDIT : The FWD pistons was meant to 26.4, not 24cc. You can find that info on the CRCalculator located in the left sidebar.
          • 4555
          The link was also to here for the plenum for sale in the buy/sell/trade section. I can't believe they edited out all links to this site when they only have people with limited knowledge on the 60* motors. Come on, they are still convinced that the 3500 heads will fit a 3.1/2.8 bore and Ben (SappySE107) has the pics on here to prove it, who BTW runs the site and the store.
            • 13531
            We show them the same kindness now...but no one ever links to them anyway cause they have nothing worth looking at.
            We can certainly set you up with a stock appearing motor other than the plenum will be larger than stock. Get the blank upper off a 3400 from 96-99. Some cars got them, some got 3400 on them. There is a rare car with a 3100 labeled large port plenum that uses the 94-99 EGR. 3100 mpfi posted it, and I forget what it was now.
            First main issue is your ECM. It has to go. Wire it up for OBD2, or wire it up for memcal OBD1. 94-95 3100 ecm is not programmable and will make any real effort of power a waste of time and money. Depending on your dependency to that vehicle, it may be easier to get a newer vehicle.
            For what you are doing, I wouldn't decline on the DOHC. 94 DOHC is tunable if you swap the wiring harness. Will love higher revs and has a better powerband for circle track than a 3100. You can leave it stock appearing, change the cam timing (not keyed so you can time it however you want, meaning you can tweak your powerband for the track with the right tools). Use thicker oil and it should be good. You can go with lighter lifters, as I doubt those would be inspected and if they were, you would have to know that stock weighs more to notice. There is a performance belt from cloyes now, though no one here has it yet that I know of, or at least used it for any length of time to determine its worth.
            Get a trans cooler. Overfill the trans 2 quarts. Use type F fluid. Im not sure what trans mods you can do but if you can modify it, shim the accumulators and install the shift kit. Possibly more, dunno budget.
            If you want to stick with the pushrod, we can make it good but porting the manifolds would be trick. Acid porting maybe? Never done it as I don't have to follow rules for street cars.
            Wanna go crazy? 3.4 DOHC pistons, 3500 heads, 3400 engine. on a .040 overbore I measured 12.4:1 compression using the 96-97 pistons.
              • 4555
              I go there mainly because there are some knowledgeable forced guys, even thought they are on 90* motors. I was going to PM community to get him here anyways, but he found you . I think it's crap that you can't post links to "unsponsored" sites, they just want to get your money Ben, LMAO.
              I also like that even though you sell your service, you don't keep secrets and we can all benefit form eachother
              • sharkey
                • Jun 2004
                • 2061
                the 2.0" exaust is a real killer, most 60*v6 engines came with bigger than that from factory.
                i wouldnt rule out a dohc swap. with minor tweaking well over 225hp is possible, so it would be worth it even with the 100lb weight penlty. even if you did go with a pushrod motor, how much do they enforce the rules??? you could do the 3400 with camaro 8cc pistons and have 12.7:1 compression, but are they going to tear the motor down for inspection???
                the rules seem very open to interpertation. now it says the tranny and converter must be stock, but is that stock as in no modified, or stock as in came in the vehicle??? if you can, id run a th125 and a factory 2950 stall converter. didnt come stock in that car, but all oem stuff. the 125 would save a bit on weight and rotating mass. you could run an obd1 harness and ecm for a 5 speed, and burn chips for it.
                  • Apr 2007
                  • 30
                  okay then.. lets break it down.
                  Do I need to pull motor out of car or can conversion be done in car ?
                  Are there are parts like gaskets, seals, brackets, mounts, so forth which are needed ?
                  How about computer stuff, sensors, wiring harness, mods, over drills, re-drills ?
                  Can we maybe put together a Step 1 do this, Step 2 do that type of list ?
                  Seems to me some stuff is simple and just swapping parts.. otherstuff like over boring the block and/or shaving the heads are more expensive.
                  What about a valve job, what about porting..
                  And is this engine I want maybe for sale already on someone's bench ?
                  OR maybe some Mid-Western (Michigan) 60* V-6 Engine Builder would like to join my racing effort and get some hands on grease going..
                    • Apr 2007
                    • 30
                    Something else the car really needs.. it turns like a tank.
                    I need a way to get 8 to 10 degrees camber into the right front.. any thoughts ?
                      • 4555
                      You can leave the engine in the car, if you can pull the pan to unbolt the rod caps to change the pistons. In my car it's possible, but don't know about your FWD. You can't covert your 3100 into a 3400 because the bore would make your walls too thin.
                      If you use stock sized pistons (3.1 Camaro/Firebird), you won't need to bore, just a hone will be fine (depending on condition of the cyl walls), but the bore would give you a few extra cubes.
                      Since you have aluminum heads already, your brackets etc should work fine with 3400 heads, same gaskets as if you did a rebuild.
                      First decide on where you want to go with this. Are you going to keep your block and do a top end swap, or are you going for a different motor?
                      For a top end swap, start by finding heads with the casting numbers given to you. If it's out of a JY, them get the manifolds etc as well.
                      Don't know what kind of budget you are working with, but Ben sells all the top end stuff new here on the site (and he can re-grind a cam for you IIRC)
                        • Apr 2007
                        • 30
                        what is IIRC ?
                          • 4555
                          Originally posted by communityracingchallenge View Post
                          what is IIRC ?
                          If I Remember Correctly
                            • Apr 2007
                            • 30
                            Okay.. I found a minor error, getting ready to start the job, discovered that this car is a 91 Grand Prix. Not a 94. Working with Race Cars which don't have dashes in them or door stamps, sometimes this information gets lost. So I have an ECM, its not OBD1 much less OBD2.
                            So this is going to be the process..
                            Step 1) Pull motor out of car.
                            Step 2) Disassemble top half and bottom half.
                            Step 3) Pull Oil Pan, Remove Crank, Drop Pistons.
                            Step 4) Replace Stock Pistons with 3400 Pistons (DOHC or Camaro ?)
                            Step 5) Fresh Rings and Oil Pump.
                            Step 6) Reassemble bottom half.
                            Step 7) Remove intake manifold, exhaust manifold, heads and plennum.
                            Step Replace everything with 3400 parts - except
                            Step 9) Use custom ground high performance cam
                            Step 10) Use 3500 plennum
                            Step 11) Reassemble top end
                            Step 12) Put back in Car
                            Step 13) Go FASTER !
                            Questions:
                            1.) Are we sure that all the parts above are plug and play ?
                            2.) Is the electrical going to work, or are new sensors/modules needed ?
                            3.) Is the computer adequate or is all work going to be lost with old computer ?
                            4.) Can a chip or "hotter" ECM be purchased ?
                            Are there tranny mods which would be benefitial ?
                            Any other go fast ideas ?
                            Thanks,
                            Patrick
                              • 13531
                              I have a 91 grand prix, and its obd1. Its the setup I learned to tune on. I can do anything you want to if if you stay naturally aspirated
                              You have a gen 2 motor, which will look nothing like a 3400 upper intake. You can do a hybrid swap. You have a flat tappet cam, so comp, crane, crower, lunati, etc make cams for it.
                              You would need a 3400 block to use the camaro or DOHC pistons. camaro give 10.8:1 and DOHC give you roughly 13:1 with 3400 top end.
