Replace 94 Olds Cutlass 3100
  • jjmag92161
    • Mar 2004
    • 2
    What other year 3100's and can I use to replace in My 94 Cutlass.
    Thanks
    94 Cutlass Supreme 2Dr 3100
    97 Silhouette 3400
    • 9191
    • jjmag92161
      • Mar 2004
      • 2
      Replace 3100 in 94 Olds Cutlass
      Thanks for the info!!
      97 Silhouette 3400
        • 13531
        94-95 drop right in, 96-99 use a different plenum/EGR setup but thats just an adapter to use them. 00-04 are different again. Brad, are you sure the cam sensors are compatible? I know you were looking into them but I don't know if the computer cares either way of if its just the sensor/pickup matching that matters.
          • 9191
          Cam sensors work up to 02. As far as the 03+ ones, I'm not for sure. With the design on the cam, there is a chance that it won't work. But I am running the 00 cam sensor in my 3400 (different design) and my ECM picks it up just fine.
          • cutlassconvertible
            • Mar 2004
            • 15
            Hey does anyone know if i can swap the intakes from my 94 3100 with the newer ones from like the 2000 with the bigger intake ports??
            • 95BlackRoseZ26
              • 32
              You can swap the bigger port intakes on, but you have to use both the new upper and lower. You can't mix and match the new and old intakes. Also, you'll need an adapter plate to mount your egr to the new manifolds.
                • 9191
                And you'll also have clearance issues with the lower manifold and stamped rockers.
                http://www.60degreev6.com/index.php?p=pages&pid=68
                  • Mar 2004
                  • 15
                  Hey in the article doesnt it say they fixed that clearance problem on the year 2000+ model intakes, i thought you said that they already ground it down for better clearance?
                  Also where can i get that adapter plate for the EGR??
                  thanx
                    • 9191
                    Well, I have heard that some people even had clearance issues with the manifolds that were already ground down. With that said, I would check the clearance no matter what before I started the engine. Believe me, you don't want to go through what I went through trying to get all the aluminum shavings out of the engine. Was not a fun experience.
                    As far as the EGR plate goes, that was something I made myself. I no longer have it. But there are some available, mainly on j-body and l-body forums. Some people around here might know how to get you one. Personally, I just run with mine blocked off...
