3.4 DOHC heads on a 3x00 block
  • 3100 MPFI
    • 1522
    I know a lot of people have asked if the DOHC heads can be used on a pushrod block, and we have been told "no", but I am one of those people that likes to know the "WHY" part. You know what they said about curiosity and the cat? About how it killed a couple of hours!!!!!
    I needed to remove the head on my 3.4 DOHC that I am getting ready to rebuild, so I figured that this would be a good time to do some comparing with the 3100 block I had sitting next too it.
    Just so you know, I have a 1999 3100 SFI block (physically the same as the 3400 with the exception of the BORE). I also have a 1994 3.4 DOHC. Both are in really rough shape, but these pics will show how they interplay with each other.
    First set of pics is of basic comparisons, second set of pics is of a 1994 3.4 DOHC head on a 3100 SFI block, and third set of pics is of a 3100 SFI head on a 3.4 DOHC BLOCK.
    One thing I would like to point out in these pics is that I KNOW that I put the REAR DOHC head on the FRONT of the 3100, but that should not matter. For the 3100 head on the 3.4 DOHC, the rear head is on the rear bank, but once again, it does not matter. Just wanted to point out that I am aware of this before anyone pops in about it.
    This is all REALLY cool.
    First of all, some basic pics.
    This is a bare 3.4 DOHC block:
    And this is a bare 3100 SFI block:
    One of the biggest NOTICEABLE differences is the OIL VALLEY. The 3.4 DOHC does not have lifter holes, and it has a cover on it. When the engine is ASSEMBELED, the valley is actually OPEN to the air, and not sealed off like the 3100. The 3.4 DOHC has that cover on it to keep anything from getting in there.
    Here is the cover on a 3.4 DOHC:
    This is me holding the cover in place on a 3100 block:
    Now for pics of the DOHC items on a 3100 block.
    First of all, this is a 3.4 DOHC HEADGASKET on the 3100. Sorry it is so blurry, but the items I want to point out, I have more pics of.
    This is the first glaring difference (other than the oil valley). as you can see, half of the coolant ports are OPENED UP to the exterior of the block. If you go up to the first 2 pics, you can see the coolant passages around the cylinder. The 3.4 block is thicker and has an extra cooling port.
    Now this is the 3.4 DOHC HEAD on a 3100 block. The coolest thing is that it DOES BOLT RIGHT UP. I only have 2 bolts holding it in, but they are the same fitment.
    Now for the inconsistancies.
    First of all, this is looking at the INSIDE area of the engine. The 3.4 DOHC has oil passages to feed the oil back into the block. This is not really a problem on the 3100, however you would have to make a cover for the lifter ports that also allowed the oil return for the heads.
    This is the underside of the 3.4 head on the 3100 block from. You can see that it overhangs too much, and the coolant passages are exposed (you will REALLY see this later on in the 3100 head on 3.4 DOHC block pics)
    Here is a closeup of the exposted coolant port.
    Now here is a HUGH problem. Here is an exposed OIL PASSAGE for the head. You can see that the 3100 block has NO provision for this at all. Keep in mind that the 3.4 DOHC has to flow a LOT more oil than the 3100 because of the overhead cams, so if you were to attempt to make something, keep that in mind.
    Lastly in this set is just a standing back pic of the 3.4 DOHC head on the 3100 block.
    Now for the last set of pics. A 3100 head on a 3.4 DOHC block.
    Once again, just like with the DOHC head on the 3100 block, it bolts right up. I don't have a headgasket to show the comparison, so this is just the head on the block.
    Remember that oil passage I told you about? Here it is again. The 3100 head only halfway covers it.
    Remember those coolant passages that the 3.4 has, but the 3100 does not? Here they are exposed on the block. The head does not fully cover them, so this is a MAJOR problem.
    And here is the oil valley feed holes in the 3.4 DOHC block, but the 3100 head does not cover them.
    I know that a lot of people know this already, but some people are like me and want to know the WHY and not just take someones word for it.
    Taylor
    1998 Lincoln Mark VIII
  • 95Grand-Am
    • 268
    Nice wright up, interesting info.
    • geoffinbc
      Iron Head Enthusiast
      • 5831
      Yea it was interesting for sure. It clearly shows how the blocks differ in order to accommodate the different head styles.
      • 3100 MPFI
        • 1522
        Thanks.
        I am one of those people that when I ask WHY something will not work, the answer of "because I said so" does not always sit well with me. There is only a handful of people that can say that too me and I will accept it.
        Someone had asked about doing this over one clubL67 (also known as clubGP) and I decided to do this (not going out of my way here. I needed to work on my 3.4 DOHC, and the 3100 block was sitting right next to it). Some of those {fill in the blank} actually read it as if I was being serious about making it work.
        I write things up in the style of making it work. That is the best way to do it. If you look at it in the name of MAKING something work, then you tend to be more analytical and see some of the things that you might not notice otherwise. A good example of this is the extra cooling port on the 3.4 DOHC block.
        Anyways, This is just something fun out there and it shows just how much GM did to get this to work.
        They didn't just seal off the camshaft area, and throw DOHC heads on it like a lot of those {fill in the blank} think.
        Taylor
        • gpchris
          • Feb 2007
          • 477
          Thanks dude... I dont see why you have to insult us cgpers. I just told the guy that dohc head will not work on a pushrod block. I know exactly why it doesnt work.. I've had both engines down the block and seen exactly what you've showed here. And it doesnt make me an asshat if i dont go out and take pictures of why it doesnt work.
            • 13534
            You should add content to the site with the pics and write up. Leave out the asshat comment:P
              • 9191
              Its already there, but I found out last night (as I was walking him throuhg it), that non-admin people have alot less options when it comes to writing articles. So I need to figure out a way to make it easier for the community to add articles.
              As I told Taylor last night... maybe the wiki wasn't so bad. LOL.
              • 3100 MPFI
                • 1522
                gpchris, this was not directed at you. It was actually directed more towards someone I was talking too in AIM.
                Ben, I will delete the asshat comment just for you.
                Taylor
