3400 Top End on a 94 3100
  • BigJoe
    • Jan 2005
    • 18
    I know this subject has been talked about alot. I am pretty knowledgeable on the swap but just a few things I want to go over before I go ahead and do this.
    When using he 3400 heads do I use the 3400 head gasket, I'm thinking yes, but wanted to hear from others. Also a similar question, do i need to get 3400 head bolts or 3100? Or does it not matter?
    As for the alternator, I know it doesn't exactly bolt right up. I see it can be done but I was wondering if it would just be easier to use a alternator made for a newer Grand Am that came with the 3400. What are peoples opinions on this?
    Any other comments welcome thanks.
    www.ClubECM.com <==New Memebers Welcome!
    • 13534
    Use the newer alt if it is different. Head bolts are the same. Use the 3100 head gasket.
      You just need to get 1 bolt and a nut to bolt on the alt. I went to a 3500 plenum and it doesn't use those 2 stud/brace things. So you have the bottom swivel bolt, and then get a short bolt and nut and bolt it to the top last bolt hole on the stock alt. Works fine. The extra braces and stuff are not needed and a bit over kill. They did away with them later years as you can see.
      • zofo61
        Banned
        • Oct 2005
        • 436
        Got a whole 3400 top ready to go....just let me know.....
        • BigJoe
          • Jan 2005
          • 18
          You mean for sale? What year is it off of and how much. I had one lined up already but if the price is right I could be interested.
          • zofo61
            Banned
            • Oct 2005
            • 436
            2002 3400 top out of a MonteCarlo....make an offer shipped fed ex ground to a business. I will be out of town till Sunday evening..........Cheers
