what heads?
  • mrdontplay
    • Dec 2008
    • 11
    what heads?
    I may be getting a 2.8 out of a 91 s10 for free. I'll be putting this in my chevette. Can I use any aluminum heads on this block and what heads can I use? I'm looking to do this on the cheap. Can I do carbed with any of the aluminum heads?
    • 9191
    You can do the aluminum heads on the block, BUT you can't do a carb on aluminum heads.
    • mrdontplay
      • Dec 2008
      • 11
      So 3400 heads will work? what else needs to be changed and how hard is it to wire all the up?
      • xLeGeNDx
        Pontiac Messiah
        • Jul 2007
        • 82
        3400 heads will work BUT you will need alot of parts to do a FULL topend swap
        Heads
        Lower Intake Manifold
        Upper Intake Manifold
        Throttle Body
        Custom length pushrods
        3100/3400 throttle cable
        New radiator hoses
        Rocker Arms
        DIS and coils (if your relocating the coil packsto the 31/3400 style)
        Just to name a few things...bassiclly everything to build a complete topend of an engine but you should get the idea
        1992 Pontiac Grand Prix SE
        94' DOHC/4T60-E swapped
        94' Cutlass Supreme dash swapped
