upper and lower intake question?
  • 01pontiacse
    grand prix se
    • May 2009
    • 10
    i have a 01' prix wit 3100sfi i was wondering if i could change my lower and upper intake without having to change anything else or what upgrades would you guyz recommened while im there?
  • 01pontiacse
    grand prix se
    • May 2009
    • 10
    i forgot to mention i was gonna replace it with a 3400 intake!!
      • 9191
      Other than the 3400 saying 3400, they are identical castings, so swapping them is a waste.
      • 01pontiacse
        grand prix se
        • May 2009
        • 10
        would u recommened something that would actually give me some a lil bit more pow!!
          • 13531
          You still have a 52mm TB so going with a 56mm would be a cheap and effective upgrade. Porting and going with a larger billet throttle body would work well too. It depends on your budget and goals.
          • 01pontiacse
            grand prix se
            • May 2009
            • 10
            would it be better to have both upper and lower intake or just upper? right now i have the 3400 upper intake manifold w/ throttle but imma put a 65mm
              put on a 3500 UIM with that 65mm TB. There is your power gain.
              • 01pontiacse
                grand prix se
                • May 2009
                • 10
                would i need to upgrade anything else if i put the 3500 on?
                  Just get the TB adapter and adapt the vacuum lines. Use your old MAP sensor with vacuum lines, or splice in the 3500 MAP like I did.
                  Tuning is always good but for such a small mod not needed unless you are serious and plan on more radical stuff later. Tuning even on a stock engine can get you power.
                  • 01pontiacse
                    grand prix se
                    • May 2009
                    • 10
                    for now i just plan on gettn exhaust eibach lowering springs the 65mm and the upper intake right now i just have a short ram air intake
