Originally posted by 01GPGT
View Post
Block modifications
the Olds pattern is compleately different from the 2.8 I think you are thinking of the 200r4 not the th200c (iirc what its called)1999 Olds Alero 2.4 to 3500 swap (running). totaled by a honda
14.96@91.47 in the 1/4
9.63@74.36 in the 1/8th
i had a 85 Monte with a thm200C thing had like 3 bolt patters on it. i know it bolted to 4.3L and the olds 350 i had
but any it is a diffrent trans then the 700. and the pics i have seen show the driver side closed off92 LeBaron Convert: Does it run yet? 03 Silverado 2500HD ecsb 4x4 6.0L: dual 3" in/out race "muffler" 2005 Ford Taurus SE 3.0: DD from california
4.3 is the same as the chev v8 patteren and the Olds is the same as Pontiac and Buick. I think all th200r4's had dual bolt pattern
I might run out to the yard after work tomorrow and take a look at the 86 firebird that they have and see what the 700r4 looks like. I am almost 100% sure that the 200c that I had would work with a fwd block after cutting up the cast aluminum TC cover and drilling out one of the bolt holes in the trans for the dowl pin on the block1999 Olds Alero 2.4 to 3500 swap (running). totaled by a honda
I got the trans out of the customer's car, but haven't had time to examine it yet.
