Wiring Harness LQ1 aka 3.4 TDC
  • 1988GTU
    LB62LHObbqftmfw
    • Nov 2005
    • 2475
    If one were to look into taking a 96GTP with the 32 valver and swap in a lX9, would the stock GTP harness be retained or would it be best to swap the harness? If the answer is swapping the harness, what harness would you use?
    Also, what about the PCM, wouldn't you use the the 96 GP 3100 PCM so you can DHP tune it? Lastly, what about the crank trigger, will the 60*v6 crank trigger clear that lower subframe motor mount?
    That is all. ...... for now.
    • 9190
    http://60degreev6.com/forum/f136/swa...or-3x00-t44387
    That will probably be a good read and go from there on other questions.
    • 1988GTU
      LB62LHObbqftmfw
      • Nov 2005
      • 2475
      I did read that, but the differences is that, that car is obd1 and manual.
      • 1988GTU
        LB62LHObbqftmfw
        • Nov 2005
        • 2475
        ahoo!
          Guzuntight!
          • 1988GTU
            LB62LHObbqftmfw
            • Nov 2005
            • 2475
            Arigato!
            • 1988GTU
              LB62LHObbqftmfw
              • Nov 2005
              • 2475
              wtfbbq?
                If you cant swap to a 97 Venture PCM or something, you can run the 3x00 on the 3.4 code, just have to tune it. External crank trigger will clear, read PCGUY's thread...
                Robert Saar is running his 3100 on DOHC code (OBD1 PCM though), the VE tables are close, spark is way too much though.
                I would imagine the cam sensor would probably work like the 3x00 ones do... I can't think of anything else.
                  keep in mind, my idea of way too much is about 3* IIRC... but that's 8.5 digits in base-16... too sloppy for my liking.
                  • 1988GTU
                    LB62LHObbqftmfw
                    • Nov 2005
                    • 2475
                    Okay then.
                    If anyone with a OBD2 lq1 that has went to 3x00SFI while still retaining OBD2 can respond to this thread with their experiences, that would rock!
                    • 1988GTU
                      LB62LHObbqftmfw
                      • Nov 2005
                      • 2475
                      119 Views and no one has any stout answers?
                      • 1988GTU
                        LB62LHObbqftmfw
                        • Nov 2005
                        • 2475
                        Were there any 3100 or 3400 engines that got the 65E?
                          The newer impalas and Monte's did. And GP's.
                            2000-up 3100 W-bodies did... not sure about when the 3400s did.
                              Same time I would assume. I know 2001 Impala 3400 is 65e.
