Well, if it helps at all, my plan is to use a 2000 Impala 3400 Pcm & Harness, using ext crank trigger for the LX9 and retuning it with HPTuners.
Wiring Harness LQ1 aka 3.4 TDC
As of April 2
Engine: 2006 SV6 3500 LX9
Trans: 2002 Getrag F23 5speed
Injectors: #36 GTPs
TB: 65mm TCE
Maf: 1999 3400 Montana.
Beverages: Ice Cold CANADIAN.
J body
As of April 2
Injectors: #36 GTPs
TB: 65mm TCE
I have many different Cars lol,
I am wanting to do something a little unique.As of April 2
Injectors: #36 GTPs
TB: 65mm TCE
Yes a Cav,
Wont be till April though, so have from now till then to get everything ready.As of April 2
Injectors: #36 GTPs
TB: 65mm TCE
again, http://60degreev6.com/forum/f136/swa...or-3x00-t44387
That might have answers to the mounts?
And seriously, just run the LX9 on the DOHC code... Just change the VE and spark...sigpic
if by VE you mean MAF tables, he may not even have to do that. but spark will likely need attention.
I am really curious on how to mount the TCE crank trigger setup with the mounting of the W body mounts. Is it going to be like the spooky mount config where it's going to need to be really all out custom fabricated?Lifting my front wheels, one jack at a time.
Is that different than PCGUY's 96? That aluminum piece on the 3500 BTW isn't correct for W body.sigpic
